What type of wire to use?
Old May 24, 2003 | 10:03 PM
Liquidgsr's Avatar
Default What type of wire to use?
I am going to get hardwire a inverter and im trying to wire the remote switch for my amps. I have tried a numerious kinds of wires for the amp remote but they keep melting and smoking. I was wondering if anyone knew what type to use and the guages, same for the the inverter. What time of wire should i use?
Old May 25, 2003 | 08:44 PM
o_Rage_o's Avatar
Default Re: What type of wire to use? (Liquidgsr)
your remote wire is a low current (like 300ma) wire...if its frying - you got serious other issues to worry about.
Check your wiring. Remote wire can be like 24 gauge (the smallest stuff used to alarms)
-Rage
Old May 26, 2003 | 01:25 PM
PupaScoopa's Avatar
Default Re: What type of wire to use? (o_Rage_o)
You're not powering the inverter off the remote wire right?
If you want your inverter on when the head unit is powered on, simply use the remote lead to close a relay that switches high-current to your inverter. Otherwise, find a circuit in your fuse panel that the key switches on/off. This will power your inverter on/off at the key instead of the head unit.
crystalblue99lude
Audio / Security / Video
Aug 2, 2005 07:45 PM
sooo_slow
Feb 28, 2005 03:21 PM
IgotV-tec!
Jul 7, 2003 04:38 PM
R0476
Mar 8, 2003 08:54 PM
SonicGSR
Jun 5, 2002 05:38 PM
