What Does A Cap Do?
Old Sep 20, 2003 | 09:59 AM
RiceRacist's Avatar
Default What Does A Cap Do?
Just wanna know what a cap does. I have a lot of **** that eats up power such as the system listed in my sig, blue underbody neons and I dont want dimming. Will a cap help my car not to dim? Hard to install?
Old Sep 20, 2003 | 10:02 AM
FatJoe's Avatar
Default Re: What Does A Cap Do? (RiceRacist)
not 100% sure but i think caps are basically for keeping a constant flow of watts going to your sub, instead of having a dynamic flow.
notto change the subject or anything but...ur name is riceracist and u have underbody neon lights on ur car? uhhh... correct me if im wrong but that seems kinda ricey to me...
Old Sep 20, 2003 | 10:10 AM
SOUNDSFAST's Avatar
A cap supplies your amplifier with extra voltage when needed. S in other words when your battery doesn't have quite enough voltage a cap will make up for it within reason. rule of thumb is that a 1 farad cap is good for 1000 watts. What I would use is a product called a BAT CAP. The problem with a cap is discharges too quickly for spl type systems, a bat cap will take up to 30 seconds to discharge depending on the model. Also a cap shouldn't be more than 6 inches away from your amp to be affective and no they are not hard to install. It goes inline on the power wire to the amp and then it needs to be grounded. If you are interested in a bat cap let me know and I can sell you one.
Old Sep 20, 2003 | 10:22 AM
GSteg's Avatar
so many are confused as to what a capacitor does.. -_-'
a capacitor STORES energy. it can't create energy at all.
personally, i woudln't use a cap. why? because i don't listen to my music loud enough that my amps draws so much currect from the battery. also, i would buy the farads by how much currect your amp needs. put a 2 farad cap on a US Amp 2000x and on a DEI 2400d. even thought the US amp makes a tad less power (unmodified), it will eat up more power than the DEI will.(2000+ watts of Class A/B owns you..)
Old Sep 20, 2003 | 10:24 AM
SOUNDSFAST's Avatar
Default Re: (GSteg)
Yes a cap does store energy but it also releases it when the amp needs it.
Old Sep 20, 2003 | 10:27 AM
GSteg's Avatar
Default Re: (SOUNDSFAST)
the comment wasn't made towards you.
Old Sep 20, 2003 | 10:32 AM
pjnuts19's Avatar
i wouldnt use a cap either........my system dims when i turn it up, but that doesnt bother me becasue i never turn it up to its full capability
Old Sep 21, 2003 | 05:13 PM
underESTIMATED's Avatar
Default Re: (pjnuts19)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pjnuts19 &raquo;</TD></TR><TR><TD CLASS="quote">i wouldnt use a cap either........my system dims when i turn it up, but that doesnt bother me becasue i never turn it up to its full capability </TD></TR></TABLE>
Thats putting a strain on your altenator and/or battery. Maybe when you go through one of those, you will take what you just said, back.
Old Sep 21, 2003 | 10:26 PM
philly-O's Avatar
Default Re: (underESTIMATED)
caps also serve as a filter and evens out the sound of the system. you will notice a difference in the tightness of the music. the best thing you can do is to upgrade the alternator because stock alternators put out only a few more than the vehicle requires. upgrading the ground wires will also help light dimming too.
Old Sep 22, 2003 | 01:02 AM
vteg's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underESTIMATED &raquo;</TD></TR><TR><TD CLASS="quote">
Thats putting a strain on your altenator and/or battery. Maybe when you go through one of those, you will take what you just said, back. </TD></TR></TABLE>
If you are dimming when you turn up your music the cap will not help either. It adds an extra strain on your alt, and may kill it faster. IMO, caps suck. Upgrade the grounds and alternator.
Old Sep 22, 2003 | 01:22 PM
PupaScoopa's Avatar
Default Re: (vteg)
^^^ I agree. The amplifier has capacitors built in anyway.
Old Sep 22, 2003 | 01:38 PM
rcurley55's Avatar
New User
Default Re: (PupaScoopa)
shouldn't this tread title be: What is a capacitor advertised to do....
Old Sep 22, 2003 | 02:54 PM
vteg's Avatar
New User
Default Re: (rcurley55)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rcurley55 &raquo;</TD></TR><TR><TD CLASS="quote">shouldn't this tread title be: What is a capacitor advertised to do....</TD></TR></TABLE>
Of course
Or "Caps: Don't believe the hype"
Old Sep 22, 2003 | 04:26 PM
Jagan'92's Avatar
Default Re: (vteg)
Are you guys engineering majors?
Old Sep 22, 2003 | 05:34 PM
rcurley55's Avatar
New User
was an engineering major...got my BSME in 2000
Old Sep 22, 2003 | 05:38 PM
PetroGuyX's Avatar
so basically everyone is saying caps suck, so i'll jump on the band wagon, i've installed caps many-a-time and i have yet to see a noticable difference in ANYTHING, including stuff with the battery, dimming of lights, and all that good stuff
Old Sep 22, 2003 | 06:01 PM
GSteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rcurley55 &raquo;</TD></TR><TR><TD CLASS="quote"> was an engineering major...got my BSME in 2000 </TD></TR></TABLE>
Old Sep 22, 2003 | 06:28 PM
rjr162's Avatar
Default Re: (PetroGuyX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PetroGuyX &raquo;</TD></TR><TR><TD CLASS="quote">so basically everyone is saying caps suck, so i'll jump on the band wagon, i've installed caps many-a-time and i have yet to see a noticable difference in ANYTHING, including stuff with the battery, dimming of lights, and all that good stuff</TD></TR></TABLE>
I have noticed a difference... granted small and pretty much useless. My ex-coworker had a Tiburon with a Concept 2400 and 2 Treo SS's (or whatever the 1000 watt rms subs are). The voltage held for just a fraction longer when the bass hit. Obviously it's only useful where the bass hits were infrequent giving the system enough time to charge the caps in the amps as well as the power lines. In my mind... pointless. The only thing it did help was keep the voltage around 11.2 rather than the 10.4 he was seeing on the quick loud hits. Pretty much it just gave enough power to keep the battery from being dipped as low because it wasn't quite used as long. But still, going from the 14.4 of the alternator to 11.2 produces a major drop in brightness of the headlights and also power output from the amp. In my mind... a waste. The amp has the caps it should need build in.
Old Sep 22, 2003 | 08:18 PM
philly-O's Avatar
Default Re: (rjr162)
i have a 165 amp alternator, stinger 800cca drycell bettery, and a 1 farad metered cap and upgraded all wiring in the car. i am runnning 2 soundstream 500's (1 for each sub) and 1 soundstream 300 for my components, my voltage only dips from 14.8 at idle to 14.2 while cranking it.
Old Sep 22, 2003 | 08:54 PM
rcurley55's Avatar
New User
Default Re: (GSteg)
GSteg...and you're trying to say WHAT exactly?
Old Sep 22, 2003 | 09:02 PM
GSteg's Avatar
oh nothing..u know me..just bored.
btw..u have the ID midrange in kicks yet?
Old Sep 23, 2003 | 01:26 PM
Jagan'92's Avatar
engineers rule the world. i'll be so glad to graduate.
my 1f cap does do one thing well - it kept the voltage spikes from my noisy engine out before i got new wires. not like that had anything to do with sound quality.
plus now with a cap i have a potentially dangerous explosive battery which could accidently discharge if something shorts it out! yeah!
firestarr2474
Audio / Security / Video
Dec 10, 2005 06:21 PM
Bone Stock
Mar 21, 2005 09:02 PM
ChronicFrogs2004
10
Aug 2, 2004 02:53 PM
Finest
Aug 5, 2003 09:32 PM
101998
Feb 12, 2003 06:43 AM
