do i need a cap?
Old Dec 9, 2005 | 11:23 AM
firestarr2474's Avatar
Default do i need a cap?
ok in my type s im gonna have an audiobahn a8000t amp runnin at 2 ohms, its rated at 800rms and 1600 peak, the true power will be a lil less than that but i bought a 1.0 farad cap.
would an rsx's alternator be able to handle that or did i make a stupid noob mistake
this is the first audio related upgrade ive done to my car besides my new head unit so i obviously dont know much and am curious if i wasted my money
Old Dec 9, 2005 | 12:12 PM
Sex Cells's Avatar
Default Re: do i need a cap? (firestarr2474)
dont install a cap
Old Dec 10, 2005 | 02:48 AM
nsxxtreme's Avatar
You didn't make a noob mistake. I dont know much about that alternator so maybe someone else can fill you in. A cap is a good addition.
I= C*dv/dt I'll let you do all the math.
I try my hardest to stay out of the cap debates because 95% of the people don't know how to use them correctly.
I'm still waiting for someone to tell me how they are an additional load on the electrical system. I like to share info but it will cost you some effort. Nothing is free in life.
Old Dec 10, 2005 | 04:15 AM
Gen2Integra23's Avatar
Default Re: do i need a cap? (nsxxtreme)
i would install the cap
it will only help your electrical system
Old Dec 10, 2005 | 12:09 PM
fcm's Avatar
fcm
Old Fart
Yes get a cap, just make sure it's installed properly. IMO if installing amp/s that have an RMS rating above 500W, you should upgrade the alt., however unless you are cranking the snot out of it all day long, and you install the cap, you should be OK, do this, take the car to a batt. shop and have them check the system, the will tell you what the output of the alt. is, [most will do this for free] and then 6mo. or a year from now go back and check it again, if there is a significant drop in the output of the alt., you may want to replace it with a bigger one. 94
Old Dec 10, 2005 | 12:24 PM
komodo9's Avatar
A cap could only help if it's connected properly.
Old Dec 10, 2005 | 06:21 PM
Andrew619's Avatar
x2 ^
Bone Stock
Audio / Security / Video
Mar 21, 2005 09:02 PM
2fast4udude
24
Feb 4, 2005 02:11 PM
RiceRacist
21
Sep 23, 2003 01:26 PM
ilikemyaccord
Jul 13, 2003 07:36 PM
KooK
May 20, 2002 09:35 AM
