What amp?
Old Dec 24, 2006 | 09:30 AM
shawn69's Avatar
Default What amp?
what amp would you guys recomend to power 2 Infinity Perfect 10.1 10" Subwoofers?
heres a link for the subs
http://www.infinitysystems.com/carau...er=KPE&Cat=SUB
Old Dec 24, 2006 | 09:55 AM
fcm's Avatar
fcm
Old Fart
Default Re: What amp? (shawn69)
Your subs are 4 ohm 350W continuous, with 2 of them you will need a 1x700W-800W RMS into 2 ohms mono block sub amp, or two 1x350W-400W RMS into 4 ohms mono block sub amps, there are a lot of them out there. 94
Old Dec 26, 2006 | 06:23 PM
civic_driver's Avatar
i have the perfect amp for you at a very low price... check out the link in my siggy.. the amp is listed for sale in there.. it's an mb quart amb.. check it out
Old Dec 27, 2006 | 07:30 AM
fcm's Avatar
fcm
Old Fart
Default Re: (civic_driver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_driver &raquo;</TD></TR><TR><TD CLASS="quote">i have the perfect amp for you at a very low price... check out the link in my siggy.. the amp is listed for sale in there.. it's an mb quart amb.. check it out</TD></TR></TABLE> Sorry, not so "perfect", in fact it is way under-powered & 2x200W into 4 ohms, and as he has two 4 ohm drives, that can be wired for 2 or 8 ohms, the MB Quart amp, [although a good amp] is not stable below 4 ohms and would only make 200W into 8 ohms. 94
Modified by fcm at 9:33 PM 12/27/2006
Old Dec 27, 2006 | 04:30 PM
shawn69's Avatar
Default Re: (fcm)
well it turns out i only could buy 1 sub
so thats what i did, how perfect is that amp for just 1?
Old Dec 27, 2006 | 08:36 PM
fcm's Avatar
fcm
Old Fart
Default Re: (shawn69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shawn69 &raquo;</TD></TR><TR><TD CLASS="quote">well it turns out i only could buy 1 sub
so thats what i did, how perfect is that amp for just 1? </TD></TR></TABLE> For one sub it is perfect, 1x400W RMS into 4 ohms, just what you need. 94
Old Jan 3, 2007 | 08:51 PM
shawn69's Avatar
Well i was thinking of buying a brand new amp.
What is the difference between 2ohms and 4ohms? could i use an amp that has 500W x 1 (2 ohm mono) such as the phoenix gold OCTANE-R 5.0:1?
or would i be better with the OCTANE-R 4.0:2?
Old Jan 4, 2007 | 07:24 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shawn69 &raquo;</TD></TR><TR><TD CLASS="quote">Well i was thinking of buying a brand new amp.
What is the difference between 2ohms and 4ohms?</TD></TR></TABLE> Technically 2 ohms.
Ohms is a measurement of resistance, in this case, simply put, 4 ohms is twice the resistance of 2 ohms.
With some, [most] amps the RMS output of the amp doubles when you half the resistance, EG: a mono amp that is 1x200W RMS into a 4 ohm load will be 1x400W RMS into a 2 ohm load, [and as mentioned, this is not the case with all amps].
In your case you have a 4 ohm 350W continuous, [RMS] sub, so if you are getting another amp find a mono block sub amp, [1 channel amp designed specifically for sub bass] that makes at least 1x350W RMS into 4 ohms, 1x400W RMS into 4 ohms would be better, IMO "overpowering" is better then "under-powering". 94
Old Jan 4, 2007 | 08:30 AM
nsxxtreme's Avatar
or would i be better with the OCTANE-R 4.0:2?</TD></TR></TABLE>
Octane series sucks IMO. PG along with everone else has slid down hill IMO.
I borrowed one of my firends Octane amps for my boat before I bought my own amp. Junk nothing but junk.
Old Jan 4, 2007 | 03:44 PM
shawn69's Avatar
Default Re: (nsxxtreme)
alright well i was thinking a JL audio 500/1 Class D Monoblock Subwoofer Amplifier but under rated power it says: 500 W RMS @ 1.5 ohm - 4 ohm (11V-14.5V)
won't this make a big difference?
i was thinking of that amp, the infinity REF611A 600 Watt Class D amp
or a Sony XM2002GTR 2-channel Car Amplifier 200W RMS x 2
which one would be recomended?
Old Jan 4, 2007 | 04:19 PM
fcm's Avatar
fcm
Old Fart
You can't go wrong with the JL Audio 500/1, but stay away, far away, from the Sony, it may Xplode. 94
Old Jan 5, 2007 | 04:11 PM
shawn69's Avatar
Default Re: (fcm)
I can't afford the 500/1
so what do you think about the Infinity 611a?
Old Jan 5, 2007 | 04:17 PM
fcm's Avatar
fcm
Old Fart
The Infinity will do the job, [1x657W into 2 ohms] 94
JDMcivicSiEG6
Audio / Security / Video
Mar 12, 2008 09:02 PM
{Powered by VIII}
27
Jan 15, 2006 09:10 AM
deeweezy187
Apr 16, 2005 03:50 PM
JohnnyLux
Dec 14, 2004 09:27 PM
erikiksaz1
Jul 16, 2004 03:38 PM
