amps?
Old Dec 14, 2004 | 10:05 AM
JohnnyLux's Avatar
Default amps?
im a newb to subs and i have a 12" cerwin-vega sub rated at 800w @ 4ohms. The amp that was on it was a rockford fosgate 250s i think and it was in a ported box. What kind of specs on an amp should look for to use this sub at its full potential?
Old Dec 14, 2004 | 10:50 AM
buddha1320's Avatar
Default Re: amps? (civic90)
get at least a 500 watt amp so that your sub nor your amp will be working as hard
Old Dec 14, 2004 | 06:54 PM
JohnnyLux's Avatar
Default Re: amps? (buddha1320)
i was looking at a 600 watt amp, so should i get a 2-channel and bridge it to put out 600 watts or does it not work that way?
Old Dec 14, 2004 | 07:04 PM
keemosaki's Avatar
for single sub at 4 ohm, it is ideal to get a 2 channel and bridge it. Most power out of the amp... usually sounds pretty good as long as the amp can handle it. I recommend not rockfordfosgate but either a mtx, jl audio, or memphis amplifier for mid-performance. higher end... do some research or check out cardomains site. rated and priced.
Old Dec 14, 2004 | 09:27 PM
JohnnyLux's Avatar
Default Re: amps? (keemosaki)
thanks ill check those out. any other ideas?
imadigitalgod
Audio / Security / Video
18
May 13, 2008 04:00 PM
vtec8804
Apr 19, 2007 11:58 AM
NACvicSi
15
Oct 20, 2005 12:06 PM
redteg1
Apr 9, 2002 08:46 PM
