Good Amp????
You have a 1000W continuous, [RMS] sub, [Kicker S15L7], the Hifonics amp makes 1200W into 1 ohm, wired in parallel your sub will be 2 ohms, the amp makes 900W into 2 ohms a little under-powered for the power hungry Kicker L7 sub.
You really need an amp that makes at least 1000W RMS into a 2 ohm load, Kicker has a few, the one I would recommend is the JL Audio 1000/1 or 1000/1v2... http://mobile.jlaudio.com/prod...d=440 there are a few other brands that have models that would do the job, depending on your budget.
94
94
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm »</TD></TR><TR><TD CLASS="quote">I would recommend is the JL Audio 1000/1 or 1000/1v2</TD></TR></TABLE>
Damn good amps have used both with my Solobarics.
