way to make a sound if i left my lights on...?
anyone know if i can wire up my car so that if i leave my lights on.... somehting will beep? cause my 93 cx doenst do that.....
Re: way to make a sound if i left my lights on...? (al3e)
when i installed my head unit i hooked it up so that when the lights were on my stereo also stayed on. so if my music was going then i knew my lights were on. i also only need to turn on the corner lights to play music whiile parked i dont have to start my car or turn to the key to the ACC position
Re: way to make a sound if i left my lights on...? (92civicsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92civicsi »</TD></TR><TR><TD CLASS="quote">when i installed my head unit i hooked it up so that when the lights were on my stereo also stayed on. so if my music was going then i knew my lights were on. i also only need to turn on the corner lights to play music whiile parked i dont have to start my car or turn to the key to the ACC position </TD></TR></TABLE>
sounds pretty cool. any how to's on this.
radio shack,you need a 5 pin relay and a piezo speaker.get those things and ill tell you how to wire it up.
when i instelled my head unit i hooked the. Yellow wire with a red stripe up to the acc along with the red wire with a black stripe.
EDIT:
I think the red with black wire is the wire that turns on the cigarette lighter when u turn on your lights. So the red with black wire is the one that accuraly does it i think. the yellow with red stripe was just the acc wire.
EDIT:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by al3e »</TD></TR><TR><TD CLASS="quote">alright.,...you have done this before i am assuming...... that stuff isnt expensive....right? </TD></TR></TABLE>
should be pretty cheap,i little pizzo siren is only about $3-$4 and a relay should be no more than $5,you can get them from circuit city also,or any one that does 12 volt electronics.,its really easy to wire up.
i believe wal-mart has the kit that beeps if you have your lights on. it connects to your headlight fuse in the fuse panel underneath the steering wheel
I made you a diagram.you need:
(1) relay
(3) foot wire 16-20 gauge
(1) piezzo siren
various connectors
zip ties
for a 93 cx:
run the 2 grounds to the chassis,make sure it is a good solid ground with no paint.
parking light wire is red w/ black stripe in green connector underdash near back off fuse box in driverside.
key power is black w/ yellow stripe at key cylinder harness.
(1) relay
(1) piezzo siren
various connectors
zip ties
for a 93 cx:
Re: way to make a sound if i left my lights on...? (civictypenos)
uggghhhh dope dope thanks guys i got my **** workin haha I told all my freinds that dont have the buzzer noise. and told them to do it... simple as **** thanks
there is a easier way to do it. buy a piezo from shackcessories and on the fuse box there is a plug for a buzzer, try to do a search on it, sorry I would post a picture but I do not have a digital camera...
Pandahatch
11
12-08-2004 01:49 PM
