subwoofers are quiet
Old Jan 13, 2011 | 06:30 PM
///Nick's Avatar
Default subwoofers are quiet
alright, so i disconnected my subs and amp for a while before i took my car to the shop to have a new clutch installed. after i got my car back i hooked everything back up and im not sure whats going on but the subs are really quiet. not sure why this is happening. the subs use to hit really hard and now it they just have no power at all. could either the amp or subs be blown? i did get a new fuse for the power wire. thats the only thing that has changed.
Old Jan 13, 2011 | 06:33 PM
Cobb2819's Avatar
Default Re: subwoofers are quiet
are they in a shared airspace box?? try unplugging one speaker. if it gets louder then one was hooked up backwards.
Old Jan 13, 2011 | 06:40 PM
///Nick's Avatar
both 12's are in one box but its separated in the middle. ive pluged it up correctly with neg going to neg and positive going to positive. just is really quiet. i did switch the wiring aroud and i got one sub to get a little bit louder but still is quiet. thease subs were super powerful before. do you think anything is blown?
Old Jan 13, 2011 | 07:19 PM
racebum's Avatar
you check the gain on the amp? and or balance on the deck and or front/rear fader?
Old Jan 13, 2011 | 08:30 PM
///Nick's Avatar
yes, everything is set correctly and i just tested my subs with a multimeter, the subs are fine. perhaps the amp is bad
Old Jan 15, 2011 | 04:50 PM
jason0123's Avatar
they are probably out of phase with eachother. try flipping one of the terminal wires around.
Old Jan 16, 2011 | 01:24 PM
mhart's Avatar
the amp should not be bad from you just taking it out and putting it back in.
Old Jan 16, 2011 | 11:41 PM
racebum's Avatar
did you accidently adjust a crossover frequency or push a mono/stereo switch?
Old Jan 21, 2011 | 08:17 AM
Teg LS's Avatar
check power and ground to the amp, sounds like its just a wiring issue and nothing is blown because they were just unhooked
cdawg50
Jul 1, 2015 01:47 PM
hondacivic44
Audio / Security / Video
Jul 8, 2007 08:12 AM
tegasaurus
Oct 17, 2005 10:05 AM
92orangeeg
Feb 13, 2005 05:02 PM
dav3ddt
Mar 24, 2003 12:45 PM
