Subs cutting out...
Old Oct 30, 2001 | 09:26 PM
Mr. Thunderlips's Avatar
Default Subs cutting out...
when i crank up the volume, above a high listening level, my bass just cuts out, then when i turn it back down, it will come back in...does this mean i need a capacitor? someone please help...thanks!
Old Oct 30, 2001 | 09:56 PM
redblues's Avatar
New User
Default Re: Subs cutting out... (Slo_Teg)
No it means your amp cut the output to protect your subs.
A capacitor won't do jack in this situation.
Your amp just can't supply enough clean power for the volume you want. You can play with the gain settings so the amp won't do that but you'll give up some bass over the range.
Old Oct 30, 2001 | 10:10 PM
Default Re: Subs cutting out... (redblues)
the wierd thing is, it never did this in my previous car...its really strange
Old Oct 31, 2001 | 11:15 AM
redblues's Avatar
New User
What amp/subs do you have?
Old Oct 31, 2001 | 12:28 PM
JohnnyM's Avatar
The voltgae supplied to the amps is causing the protection circuit to shut down your amps. A stiffening cap will help but I would go for a higher wattage amp. You could also upgrade your alternator for more juice...
Old Oct 31, 2001 | 02:30 PM
DixieH22A's Avatar
Default Re: Subs cutting out... (JohnnyM)
okay, i found the problem, my amp was going into thermal, and shutting down cause it was overheating...the ohm level wasnt correct and it was working to hard...or sumthin like that...well, i put a fan next to the amp, and everyhting works just fine now...
Old Oct 31, 2001 | 02:31 PM
Default Re: Subs cutting out... (Michael)
haha, my other HT name...forgot i signed on under that name
Old Nov 1, 2001 | 12:29 AM
TKBLAZER's Avatar
glad to see that you fixed you problem my man~!
Old Nov 1, 2001 | 01:27 PM
Default Re: Subs cutting out... (TKBLAZER)
there you are...you HT rogue...
professorman
Audio / Security / Video
Jan 25, 2008 08:02 PM
VietFoo
Dec 25, 2005 12:03 AM
numbnuts22715
May 7, 2005 06:39 PM
redteg1
Apr 9, 2002 08:46 PM
