How to destroy the amp?
Old Jan 25, 2008 | 10:10 AM
professorman's Avatar
Default How to destroy the amp?
What will happen to a 4 channel amp if you bridge the channels and run it at 2ohm. I hear you guys say that it is unstable, but what exactly will happen? Will it start frying stuff inside the amp? Will it overheat way fast? Will it just sound bad? What exactly happens? Just curious..
Old Jan 25, 2008 | 10:34 AM
Untamed_Hatred's Avatar
Default Re: How to destroy the amp? (professorman)
it all depends on the amp really. the power it put out (not the rms but the constant, most ppl dont realize that the rms isnt what is pushing all the time) if the amp can support 2 ohm stable bridged out from 4 channels to 2 then go for it i would not reccomend turning the gain all the way up though (risk blow either the amp or the subs)
Old Jan 25, 2008 | 08:02 PM
02 accord's Avatar
When running an amp bridged, each channel (need 2 channels to bridge) will see half the load that you connect to it. In this case, each channel will see 1 ohm. Each channel will put out 2x as much power (current) as it was designed to put out at 2 ohms, and the power dissipation in each channel will double. If you keep the gains low enough, the amp should run just fine, as long as you don't exceed the current or thermal limits. If you exceed either, you will fry the output transistors.
If you keep the gains low enough to safely run the amp, you will only get as much power as you would from a single channel.
m.glisson003
Audio / Security / Video
18
Aug 15, 2011 06:17 PM
Vesperk24
Jul 27, 2007 07:30 PM
redteg1
Apr 24, 2002 08:27 PM
redteg1
Apr 9, 2002 08:46 PM
GoLowDrew
Jul 17, 2001 09:49 PM
