sub cutting out?
Old Mar 23, 2009 | 10:49 PM
thebleek's Avatar
Default sub cutting out?
ok so i have two 12" pioneer 301r's [1000w peak] [150rms] = 2000w [300rms] for the pair.
i have a pioneer gm7100m 800w max power 350w rms amp.
the subs are single 4 ohm coils. so running +&+ -&- from both speakers to the amp inputs...would make it 2ohm.
i cant set the gain up at all on the amp. I cant play the subs loud at all. my ground is good, same with bat. I dont understand why itll play the subs @ low volume, but wont play them higher
Old Mar 24, 2009 | 12:45 AM
thebleek's Avatar
Default Re: sub cutting out?
bump
Old Mar 24, 2009 | 03:17 AM
96 EX's Avatar
is the car on or off when you try this? I know my alternator is shot so if the car isnt running it'll cut out after turning it half way up. If the car is on however, it will go full blast. I made a post about using bigger grounds in your audio system for some extra assurance. https://honda-tech.com/forums/audio-security-video-27/1800watts-grounds-2531857/
Old Mar 24, 2009 | 06:13 AM
fcm's Avatar
fcm
Old Fart
What type of fuse is in the amps power cable?
Where and how is the amp grounded?
How long is the amps ground cable?
What gauge is the amps power and ground cables? 94
Old Mar 24, 2009 | 01:01 PM
ken9's Avatar
Does it cut off on every songs you play on certain one?
Old Mar 26, 2009 | 11:28 PM
93DA9's Avatar
having the same problem.. but im running a 12' Alpine type R and a phoenix gold 1000 watt amp.. (alpine head unit)
(CAR IS ON)
i can play music with the volume high and the bass at +5..but if i wanted to go to +10 after like 10 seconds my sub cuts out..
i turned off my head unit and back on then the bass comes back..
any help?
Old Mar 28, 2009 | 03:05 PM
93DA9's Avatar
bump
Old Mar 28, 2009 | 07:35 PM
Autointeg's Avatar
http://www.rockfordfosgate.com/rftec...2&woofer_imp=1 make sure thats how you have it, and what happens? ur amp switches to protect? recheck sub and amp wiring. try swapping out subs as in with a buddy, see what happens..
Old Mar 28, 2009 | 07:36 PM
Autointeg's Avatar
(CAR IS ON)
any help?
not enough power? amps gonna go out with weak power, which model pg?
Old Mar 29, 2009 | 03:54 PM
93DA9's Avatar
phoenix gold ryval v1502
Old Mar 30, 2009 | 06:13 AM
Autointeg's Avatar
how does it sound when u slowly turn up the volumn? does it start sounding distorted? amp might not be pushing enough power to them, and does it switch to protect? try running just one and see what happens
Old Mar 30, 2009 | 08:48 PM
93DA9's Avatar
it sounds fine.. it hits clean but i think it goes into protect..i adjusted a SUB setting on my headunit and its been fine ever since..
thanks for the info though guys...
Old Apr 3, 2009 | 10:46 AM
1tru3vo's Avatar
New User
question??? not being a jackass or anything..are you guys using the same gauge wire size for ground as the power? ex: if your using a 4g power wire, make sure your ground is also 4g!.. make sure you have a good solid ground..if you have to scratch off some paint to get a clean ground and use some star washers and self tapping screws..jus make sure no to drill into your gas tank..also, is your subs wire correctly for your amp? if not, it could and will cause your subs to cut out(clip) when played at high volume!! ex: if you have a 2ch, each ch is rated at 2ohm and when bridged, you get 4ohm, make sure the woofer you have is rated a 4ohm or wire to 4ohm etc etc
teggi
Audio / Security / Video
16
Jan 2, 2012 01:54 PM
Keangdawizes
Apr 28, 2008 09:41 AM
92eg_b16
Mar 28, 2008 08:20 PM
dungsta
18
Sep 19, 2005 11:12 PM
SuperMan19
Mar 28, 2002 08:46 AM
