alarm install
Old Feb 25, 2009 | 12:10 PM
mikeycivic's Avatar
Default alarm install
Ok guys I been reading over the sticky that suspended hatch made regarding stealth installs. I have decided to attempt this myself.I dont think it should be that hard with the right guidance from you guys. I have a viper 791xv, I do not plan on using the remote start feature. I purchased all the recommended accessories for the install and since the search function on HT now SUX, I am going to try and get the necessary help from you guys. I started de pinning my setup today and here is what I de-pinned as per the sticky.
On the primary harness I de-pinned the following
red/white - (-) 200 mA Channel 2 Validity Output
violet - (+) door trigger input,zone 3
white/blue - (-) remote start activation input
On the auxiliary harness I de-pinned the following
light blue - (-) second unlock output
white/black - (-) channel 5 output
violet/black - (-) channel 4 output
green/white - (-) factory alarm rearm
light green/black - (-) factory alarm disarm
this is what they look like now
Now is there anything I missed or should have not taken out? I plan on using the factory lock/unlock system with the viper remote, so Im not sure if I pulled to many from the auxiliary harness. Here is a pic of the color chart for that.
In have another question, in the sticky it says to de-pin the horn honk, the only harness I have with a horn wire is this one, should I pull the brown wire?
I also cant figure out WTF this is for, there is nothing in the manual that has a 4 wire harness diagram
Old Feb 25, 2009 | 12:59 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: alarm install
were is the back up battery? mini siren. all the extra's that you need
Old Feb 25, 2009 | 01:01 PM
mikeycivic's Avatar
I have it all Im just trying to take things one step at a time, so I figured I would start there
Old Mar 1, 2009 | 03:32 PM
justfurebay's Avatar
subscribed
Old Mar 1, 2009 | 03:50 PM
mikeycivic's Avatar
update, all of the items have been sent to sti eater for "professional" assembly.
Old Mar 1, 2009 | 03:55 PM
suspendedHatch's Avatar
Don't use the sticky. That **** should probably be un-stickied. I don't have any control of it to update/make corrections etc. Check my site: http://causeforalarm.thecarthing.com
Kind of sad but it seems that all the work I did here giving advice and writing DIY's serve for nothing else except to make wrx-killer money.
Old Mar 1, 2009 | 04:00 PM
mikeycivic's Avatar
well i def put that site to good use, as far as wrx-killer making money from it, wellllll thats between you two.
Old Mar 1, 2009 | 06:55 PM
I going to make a new thread so you can talk about this
Old Mar 17, 2009 | 07:56 AM
mikeycivic's Avatar
Old Mar 17, 2009 | 12:45 PM
B18C_EJ8's Avatar
I miss you man....
Old Apr 1, 2009 | 12:44 PM
mikeycivic's Avatar
does anyone have a way of getting hold of desmon?????????????????????????
Old Apr 1, 2009 | 07:25 PM
VI Boost's Avatar
good luck with reaching him...i've been trying for close to 3 weeks ...
Old Apr 2, 2009 | 04:46 AM
mikeycivic's Avatar
yeh its a little ridiculous, he has half my alarm so its a little hard to finish my f'en install
Old Apr 4, 2009 | 12:35 AM
VI Boost's Avatar
hey just wanted to let you know i spoke to Des and he took care of everything for me. he should have contacted you already but if not i'm positive u'll be hearing from him soon.
thanks Des.
oh btw mikey, i planned on going to GOTB00ST's meet but i had problems with a header install so my car was down for the weekend, i remember seeing u post in the thread, were u able to go?
nyvtec89
Audio / Security / Video
Aug 17, 2011 05:20 PM
lopezchris21
May 28, 2010 06:28 PM
menappi
19
Oct 13, 2006 11:57 AM
menappi
11
Oct 11, 2006 01:07 PM
accord91h22
May 31, 2005 05:15 AM
