Sub box and amp prob.
Old Jul 30, 2004 | 03:04 PM
EJ8 GSR-T's Avatar
Default Sub box and amp prob.
Two questoins today, first off anyone have and suggestions on how to mount my sub box so it dosnt move around when i corner? second what is the best rout to run the battery cable from the battery through to the trunk? best path through the firewall???? plz help!
Old Jul 30, 2004 | 03:42 PM
civic_speed99's Avatar
Default Re: Sub box and amp prob. (userdead626)
As for the box moving.... i put velcrow strips on the bottom of mine... it sticks to the carpet in the trunk.... "L" brackets also work well...
If your running in a civic, there should be a hole below the battery box in the firewall big enough to run a power wire.... it should come out below the glovebox in the car... then just run that wire down the inner door trim to the trunk
Old Jul 30, 2004 | 06:10 PM
7808's Avatar
Default Re: Sub box and amp prob. (civic_speed99)
L brackets or a bolt through the botom of the box, also makes it hard to steal.
Old Jul 30, 2004 | 10:29 PM
EJ8 GSR-T's Avatar
Default Re: Sub box and amp prob. (fuctup)
But bolt it to what? because its masonite or whatever goes over the spare
Old Jul 30, 2004 | 11:34 PM
7808's Avatar
the thing your spare screws into
Old Jul 31, 2004 | 06:03 AM
civicjester's Avatar
on the driver side of your car there is a hole that comes out right underneath your clutch fluid resivor.. you run the power cable through that down the side of the car (under the carpet next to your seat twords the door) up and under the back seat into the trunk......make sure you run your rca's and remote wire on the other side of the car to pervent interference
LudeDude101
Audio / Security / Video
10
Jul 28, 2010 05:47 AM
jdmunlimited1
Sep 15, 2009 01:20 PM
thw_goalie
Aug 16, 2007 06:08 AM
chau003
Dec 20, 2003 11:38 AM
slowestcivicever
Jul 18, 2002 05:49 AM
