Which sub??
Old Mar 15, 2003 | 07:49 PM
akeldama's Avatar
Default Which sub??
I listen to all types of music and I'm looking at purchasing a 10" sub which will powered by a JBL 300.1 amp. Based on pure SQ alone, which subs should I consider? Right now I'm looking at:
JL 10w3v2
IDQ 10 v.3
Feel free to comment or suggest.
Old Mar 15, 2003 | 10:15 PM
JOMO
Guest
Posts: n/a
Default Re: Which sub?? (EJ1)
SQ huh?
i hear good about alpine type r's for SQ
Old Mar 15, 2003 | 10:35 PM
GSteg's Avatar
JL 10w3v2
IDQ 10 v.3
thats a tough one. i haven't heard the IDQ v3 yet, but i can say the JL sounds very good. its damn accurate if you put it in the right box. how much are you going to spend?
Old Mar 16, 2003 | 10:41 AM
OC 335i's Avatar
This year's IDs are better than this years IDQs. This year's IDQs have not been redesigned yet, but the current IDs have been. Correct me if I'm wrong.
Old Mar 16, 2003 | 11:57 AM
GSteg's Avatar
Default Re: Which sub?? (MEGA EK)
from what i heard, the IDQ is going to/have been redesigned. its just a matter of time until ID releases the sub.
Old Mar 16, 2003 | 12:39 PM
OC 335i's Avatar
Default Re: Which sub?? (GSteg)
Yeah what I heard was this summer.
Old Mar 16, 2003 | 02:16 PM
akeldama's Avatar
$150 for the one sub.
Old Mar 16, 2003 | 03:44 PM
t0p_sh0tta's Avatar
All of the specs are similar, but I'd go with the IDQ. Just because Ilike to deviate from the norm, and the lower RMS rating (overhead is good). It is probably cheaper also.
You also get a free dampening spray at sounddomain.com
Old Mar 16, 2003 | 03:58 PM
akeldama's Avatar
Default Re: Which sub?? (t0p_sh0tta)
That's where I planned on ordering it. I'm not good at resistance so... do I need a D4 or D2 if I want a final impedence of 2 ohms? Thanks.
EDIT: Also, I will probably go with a small sealed box. What volume should I be looking at?
[Modified by EJ1, 8:01 PM 3/16/2003]
Old Mar 16, 2003 | 04:01 PM
t0p_sh0tta's Avatar
I believe your amp does 300 watts at 3 or 4 ohms, so you could order either one. I would get the dual 2 ohm, so you could wire it in 4 ohm. It makes life a little easier for your amp. http://edesignaudio.com/ep/wiringtut.htm
Edit: Recommended is .4-.8 cubic feet. I'd aim for the .8 to get better low end, and maybe add some polyfill down the road.
[Modified by t0p_sh0tta, 8:04 PM 3/16/2003]
Old Mar 16, 2003 | 04:03 PM
akeldama's Avatar
I think you are thinking of the JL amp instead of the JBL. The JBL does 300 at 2 ohms and 150 at 4 ohms, but they can handle a 1 ohm load if one chooses.
Old Mar 16, 2003 | 04:04 PM
t0p_sh0tta's Avatar
I take it back then, get the 4 ohm.
Edit: lol you're quick
[Modified by t0p_sh0tta, 8:05 PM 3/16/2003]
Old Mar 16, 2003 | 04:16 PM
JOMO
Guest
Posts: n/a
2 minutes!!!!!!! he's damn uick, must have a turbo computer
Boosted-Hb
Audio / Security / Video
Aug 8, 2009 12:27 AM
soclean1k_JDM
14
Apr 6, 2009 05:20 PM
digitalcongo
89
Dec 22, 2006 10:00 PM
-DC2-
10
Mar 27, 2003 10:59 AM
spd18
37
Feb 10, 2003 09:55 AM
