Looking to upgrade my sub.
Old Mar 29, 2009 | 04:53 PM
soclean1k_JDM's Avatar
Default Looking to upgrade my sub.
Well im looking into getting a single 12" type R for my ej1 and i had a few questions first.
my current setup is two 10" old school orions they sound ok with certain songs but don't really give me the good sound quality at high volume. I don't want to have annoying bass but i want something that sounds good and something that will make my nose ich lol for those who get it. I don't need to be heard for blocks just want good clean deep bass.
Would 400w or 500w but under powering the sub and im not sure to buy the 4 or 2 ohm sub incase i want to go to 2 subs later. Also which will sound better a ported or sealed box?
Old Mar 29, 2009 | 05:16 PM
zsudz922's Avatar
Default Re: Looking to upgrade my sub.
whats the make and model of the amp you are going to use?
are you putting it in a SUV/wagon/hatch or a sedan/coupe?
Old Mar 29, 2009 | 05:19 PM
mrdeadman's Avatar
They let me pick
You need at least a 750rms amp for the type r.
Get the amp first. It can be stable at 4ohm, 2ohm, or 1ohm with 750rms.
Sealed boxes tend to hit "tighter" while ported boxes are more "boomy."
Old Mar 29, 2009 | 05:37 PM
Coupe. ive notice it tends to sound better when i face the sub towards the truck then facing the back seat.
Old Mar 29, 2009 | 05:40 PM
well the better amp i have right now is a preformance teknique 400w
and i have a cheap off brand LA sound 500w
so which sub do i get 2ohm or 4 ohm?
Old Mar 29, 2009 | 06:33 PM
zsudz922's Avatar
i think you are thinking of the 15" typer r. the 15" is 750w rms, the 12" type r is 500w rms so he will need AT LEAST 500w rms. i would recommend something around ~600w rms though.
yes, you should face the sub towards the rear.
Old Mar 29, 2009 | 07:18 PM
pear_b's Avatar
theres a few options out there that are comparable in price than the type r that will be A LOT better in performance.
DC audio Level 3 $160
Audioque SDC2.5 $140
RE SE $130 (ebay dealer)
Old Mar 29, 2009 | 09:10 PM
well the 500w should be ok till i get a better amp right?
Ported will give more boom but a closed box should be tighter like hitting on point is this right?
Old Mar 29, 2009 | 09:12 PM
AcurInteg96's Avatar
i have two type r 12s 4ohm powered by a single thousand watt amp in a sealed box and it sounds very clean and hits hard. type r is the way to go. and i have mine facing the rear seats of my DC4.
Old Mar 30, 2009 | 06:10 AM
Autointeg's Avatar
... i recommend a better enclosure, it'll help out alot, instead of a prefab one
Old Mar 30, 2009 | 06:15 AM
i got mine rhino lined by my friend at a dealership.
Old Mar 30, 2009 | 10:12 AM
mrdeadman's Avatar
They let me pick
Need the model of amps to tell you. You should really wait and get a better amp. If you underpower a sub it is more prone to "blowing" if you turn it up.
Old Apr 5, 2009 | 09:53 AM
400W max
ICBM-776
2 Channel Bridgeable Power Amplifier
24dB/OCT. Crossover Slope
Variable Subsonic Filter (10Hz-100Hz)
Variable Low Pass Filter (30Hz-500Hz)
Variable High Pass Filter (50Hz-1KHz)
Variable 18dB Bass Boost
High/Low Level Input Through RCA
Double Sided PCB
Dual Protection (Thermal/Short Circuit)
RCA Line Out (Preamp)
Power/Diagnostic LED Indicator
2 Ohm Stable Stereo
Soft Delayed Power On
Tri-Mode Capability
0.05% THD
Old Apr 6, 2009 | 12:22 AM
whats the biggest mounting depth for the front 6-1/2" will Mounting Depth 2-3/8 fit?
Old Apr 6, 2009 | 05:20 PM
mrdeadman's Avatar
They let me pick
400W max
ICBM-776
Double Sided PCB
2 Ohm Stable Stereo
Tri-Mode Capability
0.05% THD
What is the RMS output?
WILD_WILL
Audio / Security / Video
Aug 13, 2008 10:54 AM
pbizzlegsr
Oct 19, 2006 05:56 PM
calel
Dec 21, 2004 10:26 AM
akeldama
12
Mar 16, 2003 04:16 PM
all420
Dec 13, 2002 04:31 PM
