Starter kill options and Fuel pump kill?
Old Mar 14, 2002 | 02:50 PM
Spade's Avatar
Default Starter kill options and Fuel pump kill?
I was thinking if I wired in a switch off of the clutch kill switch wouldn't that work as a starter kill?
Also, how would you go about killing the fuel pump?
Old Mar 14, 2002 | 03:08 PM
dustin's Avatar
Default Re: Starter kill options and Fuel pump kill? (Spade)
Starter kill is useless... push start or just get a piece of wire and connect the starter bolt to the + terminal on the battery...
Old Mar 15, 2002 | 05:43 AM
Spade's Avatar
Default Re: Starter kill options and Fuel pump kill? (fuzznuts)
Hm, okay so an ignition kill........must research.
Fuel pump, I was thinking about a switch on the + wire that I would have to turn off when leaving the car and turn on when getting in.
Old Mar 18, 2002 | 12:21 PM
bojangs's Avatar
New User
yep. both are the same concept.. simply wire a toggle switch in series with either.. very easy..
Old Mar 18, 2002 | 06:14 PM
3RROR404's Avatar
Default Re: Starter kill options and Fuel pump kill? (bojangs)
would recommend switching the negative wire though... if you can... less of a hazard having a ground wire ground out near the fuel pump, as opposed to a power wire grounding out. BOOM! pfft
Just hope they don't know how to tow a car.
Old Jul 16, 2003 | 05:42 PM
Fuster_Cluck's Avatar
Default Re: Starter kill options and Fuel pump kill? (dustin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dustin &raquo;</TD></TR><TR><TD CLASS="quote">Starter kill is useless... push start or just get a piece of wire and connect the starter bolt to the + terminal on the battery...</TD></TR></TABLE>
So, Viper's (DEI) started kill can be bypassed if the car is push started?
I don't think that can happen if a fuel cut-off switch is installed and the switch can NOT be found
I was thinking that when I get my alarm (Viper / Circuit City) to tell the guy not to worry about wiring the starter kill if it can be push started.
Old Jul 16, 2003 | 10:31 PM
dustin's Avatar
Default Re: Starter kill options and Fuel pump kill? (Hybrid93Hatch)
Starter kill kills the starter only.
Old Jul 16, 2003 | 11:14 PM
WOTTEG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bojangs &raquo;</TD></TR><TR><TD CLASS="quote">yep. both are the same concept.. simply wire a toggle switch in series with either.. very easy.. </TD></TR></TABLE>
THis is not good advice. Particularly if the switch kills a fuel component. Imagine a loose item in tha cabin, or a stray hand/foot bumping the switch while driving.
Use relays and a momentary to constant setup.
LINKS:
Great resource:
http://www.the12volt.com
Imobilizer Idea:
http://www.autospeed.com/A_0059/P_1/article.html
Here is a store that sells Bosch relays and other electronics:
http://www.partsexpress.com/pe...ID=31
Relays MULTIPLE uses:
http://www.partsexpress.com/resources/relays.html
Replace the door handle covers with those from an RS integra:
http://itr-nc.com/pat/rshandles_small.jpg
https://honda-tech.com/zerothread?id=237232
Momentary Kill switch setup:
http://www.ae92gts.com/ae92gts_antitheft.html
https://honda-tech.com/zerothread?id=244674
If only Teken were still around:
Teken:
Wire Color codes and locations for an Acura Integra 2000
12 Volts Constant WHT IGNITION Switch Harness
Igniton 1 BLK/YEL IGNITION SWITCH Harness
Ignition 2 WHT/BLK IGNITION SWITCH HARNESS
Accessory/Heater Blower 1 YEL IGNITION SWITCH HARNESS
Starter BLK/WHT (+) IGNITION SWITCH HARNESS
Parking Lights RED/BLK GRN PLUG ABV. FUSEBOX
Dome Light GRN/RED (-) DR KICK PANEL
Pwr Door Lock BLK/WHT (-) DR KICK PANEL
Pwr Door Unlock BLK/RED (-) (TYPE B)
Tach Sensor BLU (-) AT DIST
Brake GRN/WHT (+) AT BRAKE SWITCH
Horn BLU/GRN (-) STEERING HARNESS
FACTORY ANTI-THEFT TRANSPONDER
Old Jul 17, 2003 | 04:15 AM
Default Re: Starter kill options and Fuel pump kill? (WOTTEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WOTTEG &raquo;</TD></TR><TR><TD CLASS="quote">
If the switch is mounted somewhere out of the way and is always turned on/off before the key is even put into the ignition, can there still be a problem?
Old Jul 17, 2003 | 06:45 AM
Deam's Avatar
"THis is not good advice. Particularly if the switch kills a fuel component. Imagine a loose item in tha cabin, or a stray hand/foot bumping the switch while driving.
Use relays and a momentary to constant setup."
Well, obviously, there is common sense involved. However, I would trust a toggle switch hidden in a place that will not be accidentally pumped (and I mean a switch that is not pushbutton, but must be moved by hand), much more than a latched relay system.
If that relay fails while you are driving, you are in trouble. Basically, I have trouble trusting for a major fuel component a relay that is charged and pulled in.
Old Jul 17, 2003 | 06:56 AM
Deam's Avatar
Default Re: Starter kill options and Fuel pump kill? (Deam)
Furthermore, using the ground wire as the switch is not so great, as it is much easier to defeat. The thief can just go to the fuel pump, and touch the ground wire to the chassis. But they may not be able to find a 12volt source to wire into the pump.
What I mean is, if the theif is determined enough to actually try to access the fuel pump, cutting the 12volt line is much harder to bypass then ground, because ground can be easily reconnected using chassis. But for the 12V line, the thief will have to splice another power line.
Old Jul 19, 2003 | 09:20 AM
VTECorona's Avatar
How would one go about setting up a kill switch for the fuel injectors?
Old Jul 19, 2003 | 10:23 AM
WOTTEG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deam &raquo;</TD></TR><TR><TD CLASS="quote">I would trust a toggle switch hidden in a place that will not be accidentally pumped (and I mean a switch that is not pushbutton, but must be moved by hand), much more than a latched relay system.
If that relay fails while you are driving, you are in trouble. Basically, I have trouble trusting for a major fuel component a relay that is charged and pulled in.</TD></TR></TABLE>
What do you think the <U>PGM-FI Main Relay</U> does?.
Most systems in your vehicle depend on relays. I do suggest buying the highest-quality relays available though. Bosch relays outperform other relays as Bosch's QA testing is much more rigourous than other companies. Teken had a good resource for comparative data on relay brands. I can't find it though.
LaOXXKIDD
Oct 15, 2009 11:42 AM
Civic Si Kid
Audio / Security / Video
May 17, 2009 12:26 PM
96electronH
Dec 2, 2007 05:29 PM
StreetRacnGsR
23
Jun 18, 2003 05:05 AM
Egone
Nov 5, 2002 07:10 PM
