reverse wire help needed
There are several places under the dash to connect the back-up (reverse) wire. One place is at the under-dash fuse box. There is a 12P Lt Green connector (Connector D); the Grn reverse wire is at pin 8 of that connector.
Connector terminals are numbered according to the cavities they’re in. The cavities are numbered starting from the upper left, looking at the male terminals from the terminal side or looking at the female terminals from the wire side. Both views are in the same direction so
the numbers are the same. All actual cavities are numbered, even if they have no wire terminals in them.
