reverse wire help needed
Old Mar 16, 2015 | 10:21 AM
Excess Venom's Avatar
Default reverse wire help needed
Hi,
I have a double din Kenwood stereo and it has a reverse cable that needs to be linked up, can anyone let me know what wire this is and where it's located please
Old Mar 16, 2015 | 10:50 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: reverse wire help needed
There are several places under the dash to connect the back-up (reverse) wire. One place is at the under-dash fuse box. There is a 12P Lt Green connector (Connector D); the Grn reverse wire is at pin 8 of that connector.
Old Mar 16, 2015 | 11:00 AM
Thank you for the reply, also pin 8 I'm new to this for the pins go 1-6 on top row and 7-12 on the bottom row?
Old Mar 16, 2015 | 02:16 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Connector terminals are numbered according to the cavities they’re in. The cavities are numbered starting from the upper left, looking at the male terminals from the terminal side or looking at the female terminals from the wire side. Both views are in the same direction so
the numbers are the same. All actual cavities are numbered, even if they have no wire terminals in them.
racerguy101
Jul 24, 2009 05:43 PM
type Gendy
Mar 12, 2009 08:33 AM
14bcoupe
Welding / Fabrication
12
Apr 19, 2005 11:20 AM
buzzsawstan
Jun 30, 2004 09:09 PM
