reverse light starter kill
Old Jul 29, 2004 | 12:35 PM
Stewie's Avatar
Default reverse light starter kill
I lost the thread on how to do a reverse light starter kill so that the starter will only activate when in reverse.
I just want to make sure this is the correct wiring.
30-one end of the starter wire
87-the other end of the starter wire
85-reverse light wire
86-ground
thanks
Old Aug 3, 2004 | 04:12 PM
Stewie's Avatar
Default Re: reverse light starter kill (Stewie)
bump
Old Aug 3, 2004 | 06:03 PM
Eric R's Avatar
Yes, that's correct assuming the reverse wire is a positive 12v signal.
In some vehicles the reverse wire could be negative. Test.
Old Aug 3, 2004 | 06:07 PM
Eric R's Avatar
Preferibly, use 87 for key switch side and 30 for starter solenoid side.
Eric
Old Aug 3, 2004 | 11:38 PM
Stewie's Avatar
Default Re: reverse light starter kill (Eric's R)
Old Aug 4, 2004 | 02:45 PM
IVI's Avatar
IVI
why bother now that its been posted on here?
Old Aug 4, 2004 | 03:32 PM
rjr162's Avatar
Default Re: reverse light starter kill (IVI)
there's only one problem with starter kills. If someone doesn't have your key and is going to hot wire it anyhow, then they'll see your starter wire has a relay in-line with it, and bypass the relay. Make sure if you are going to do the starter kill you either A> connect the starter kill relay in-line as far back down the ignition wires as possible so the lines look untouched, or B> Take some heavier guage wire and if possible unsolder the factory starter wire, solder yours in place, and run your wire down into the dash and someone way out of the way. Then use the relay to link your wire to the factory starter wire, this way the starter wire again looks untouched and the connection leading to the relay isn't as visible.
Old Aug 11, 2004 | 09:27 AM
Stewie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stewie &raquo;</TD></TR><TR><TD CLASS="quote">I lost the thread on how to do a reverse light starter kill so that the starter will only activate when in reverse.
86-ground
thanks</TD></TR></TABLE>
I did this and now it still starts in Neutral, but not in reverse!
I can't ****** believe it.
Can anyone tell me what happened??? Please help me out!!
Old Aug 14, 2004 | 03:44 PM
luciferi's Avatar
Can anyone tell me what happened??? Please help me out!! </TD></TR></TABLE>
It sounds like you are connected to 87a instead of 87
2x0
Apr 29, 2018 09:35 AM
stevewa
Nov 24, 2011 10:15 AM
prime-R
Mar 11, 2011 11:38 AM
dart2.2
Jul 25, 2008 09:33 AM
ShinotakuX
Mar 30, 2008 09:00 PM
