Remote Starter problems
Old Jun 1, 2006 | 11:10 AM
RNPoo7's Avatar
Default Remote Starter problems
Hey fellas.
My sister's 99 civic ex has had an older DEI alarm with remote start on it.
Well lately, the whole system starting screwing up big time.
Sometimes the siren won't work and only get flashing lights instead of lights and noise.
But tha'ts not the problem
Lately, when we try to remote start, we get "click click click noise" from the enegine bay and it doesn't start.
No idea why it doesn't start anymore, but if we start it from inside, it works fine.
Any ideas?
TIA
Old Jun 1, 2006 | 11:47 AM
fcm's Avatar
fcm
Old Fart
Default Re: Remote Starter problems (Patoot)
First thing I would check is the install, the connections, if they are not all soldered connections you probably have some bad ones, the other thing that can happen with older units is the relays go west, and you have little or on output from them.
You will need a multimeter or at the very least a test light to check things. 94
Old Jun 1, 2006 | 11:50 AM
RNPoo7's Avatar
I didn't install the system, and I don't know anything about wiring for alarms and remote starters
Old Jun 1, 2006 | 11:59 AM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">and I don't know anything about wiring for alarms and remote starters </TD></TR></TABLE>
Then take it back to the place that installed it and take advantage of DEI's lifetime warranty...
Old Jun 1, 2006 | 12:51 PM
RNPoo7's Avatar
Default Re: (B18C_EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">
Then take it back to the place that installed it and take advantage of DEI's lifetime warranty...</TD></TR></TABLE>
I don't know where it was installed. I bought the car with it. The dealership did not even know it had remote start.
Old Jun 1, 2006 | 12:56 PM
B18C_EJ8's Avatar
You're sure it's clicking from the engine bay, and not from under the dash?
Old Jun 1, 2006 | 08:27 PM
RNPoo7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">You're sure it's clicking from the engine bay, and not from under the dash?</TD></TR></TABLE>
It could be, i'll double check tomorrow. What if it was from under the dash, what does that tell me?
Thanks
Old Jun 1, 2006 | 10:21 PM
suspendedHatch's Avatar
Default Re: (Patoot)
Tell us what you need. You're saying you can't fix it yourself. Take it somewhere.
Old Jun 2, 2006 | 04:10 AM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">What if it was from under the dash, what does that tell me?</TD></TR></TABLE>
Could be a bad ground or bad relay (or relay pack).
Old Jun 2, 2006 | 06:19 AM
RNPoo7's Avatar
Default Re: (suspendedHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch &raquo;</TD></TR><TR><TD CLASS="quote">Tell us what you need. You're saying you can't fix it yourself. Take it somewhere.</TD></TR></TABLE>
I'm trying to find what out what's wrong with it.
Old Jun 2, 2006 | 06:37 AM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">I'm trying to find what out what's wrong with it. </TD></TR></TABLE>
Then answer the question where the clicking is coming from.
Old Jun 2, 2006 | 06:45 AM
RNPoo7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">Then answer the question where the clicking is coming from.</TD></TR></TABLE>
dude, chill man. I said I would. I'm waiting on my sister to get home.
Old Jun 2, 2006 | 12:43 PM
RNPoo7's Avatar
k, it's coming from under the hood. I think she has a bad battery or bad starter.
Old Jun 2, 2006 | 12:44 PM
B18C_EJ8's Avatar
But you said it starts normally with the key? If so, then it may be that a relay is going bad and not throwing enough voltage to the starter wire. Check the ground on the brain of the unit and make sure it's clean and not corroded.
Old Jun 2, 2006 | 02:32 PM
RNPoo7's Avatar
any idea where that relay might be located?
Old Jun 2, 2006 | 02:47 PM
B18C_EJ8's Avatar
Probably near the brain. But you'll actually need to crawl up under the dash and drop the whole assembly. Get us a make and model while you're up there.
Old Jun 5, 2006 | 06:56 AM
B18C_EJ8's Avatar
Well???
Old Jun 5, 2006 | 07:03 AM
RNPoo7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">Well???</TD></TR></TABLE>
I was working all weekend. Didn't get a chance yet
I'll keep you posted
MistahJuice
Audio / Security / Video
Jan 22, 2013 10:20 PM
boynblue
14
Dec 17, 2006 07:27 PM
tomu06
16
Mar 30, 2006 01:10 PM
DynastyRacer22
Jan 28, 2005 09:01 PM
allmotor.net
Jan 25, 2004 01:51 PM
