remote start only!
Old Feb 6, 2008 | 01:42 PM
Sic_DA_Nine's Avatar
Default remote start only!
its been 2 years since i had remote start in my 95 civic.
when i turn the key, no crank, no nothing....
i have to remote start it, then turn key on "on" position to start my car...which kinda sucks right now...
anybody encounter that situation?
starting the car with the key used to work...no problem..but now it doesnt
Old Feb 7, 2008 | 12:10 AM
8520's Avatar
Default Re: remote start only! (Sic_DA_Nine)
Your remote start system likely has some sort of starter kill built in and was likely butt connected. I would guess that the key side of the start kill relay has come loose while the stater side is still connected.
If I were you I'd pop of the underdash and see if you can see any loose connections.
Old Feb 7, 2008 | 05:34 AM
fcm's Avatar
fcm
Old Fart
Ditto the above.^^^^
Another thing I have seen more then a few times is when "T" taps are used to make the connections, the "T" tap will shear through the wire and after a period of time one side or the other of the tap will loose contact, in your case the key side has lost contact but the starter side is still connected.
The other possibility is that your ign. switch has gone west.
Whatever the problem is you will have to pull the lower dash trim and have a look, find the starter lead, [black/white] from the ign. switch and fallow it to where the remote starts starter lead, or starter cut relay is connected and inspect the connections. 94
myaccord2004
Feb 9, 2018 02:12 PM
bigboi407
Apr 9, 2016 04:27 PM
jay24k
Audio / Security / Video
Jan 15, 2011 06:15 PM
lshatch916
13
Nov 6, 2007 02:56 PM
JOMO
Jun 17, 2003 09:31 PM
