520T Battery Backup
Old Oct 7, 2007 | 12:44 PM
candyman206's Avatar
Default 520T Battery Backup
I'm having problems that I don't understand. I hooked up the RED wire to my radio harness for constant 12. Then I spliced directly into the wire that feeds the alarm constant 12. The black went to a ring terminal for chassis ground and here is what I don't get. I spliced into the hood pin trigger wire with the blue wire . I armed my alarm while holding down my hood pin switch and pulled the negative battery terminal and nothing happened. I tried one more thing out to problem solve, I disconnected the the blue wire and hooked it up to my DMM the other probe went to a chassis ground pulled the positive battery cable and no beep from the meter. Any help or direction would be appreciated.
Old Oct 7, 2007 | 01:13 PM
suspendedHatch's Avatar
Default Re: 520T Battery Backup (candyman206)
The blue wire goes to the alarm's trigger input. This is the wire that tells the alarm to go off. If you have it connected to a pin switch, how does the alarm know the alarm has lost power?
The red and gray wires go inline with the alarm's power source. You cut the power wire to the alarm, connect the bb's red to the power side, the gray to the alarm side.
Old Oct 7, 2007 | 01:53 PM
so simple's Avatar
also RED on a radio harness is ACC
Old Oct 7, 2007 | 05:15 PM
fcm's Avatar
fcm
Old Fart
Default Re: (so simple)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by so simple &raquo;</TD></TR><TR><TD CLASS="quote">also RED on a radio harness is ACC</TD></TR></TABLE> But BBs red and gray have to be connected to alarms constant power, not the radios. 94
Old Oct 7, 2007 | 05:19 PM
so simple's Avatar
oh oops read it too quickly. i thought he hooked up the BB constant to a radio RED/ACC
Old Oct 7, 2007 | 05:40 PM
Default Re: 520T Battery Backup (suspendedHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch &raquo;</TD></TR><TR><TD CLASS="quote">The blue wire goes to the alarm's trigger input. This is the wire that tells the alarm to go off. If you have it connected to a pin switch, how does the alarm know the alarm has lost power?
The red and gray wires go inline with the alarm's power source. You cut the power wire to the alarm, connect the bb's red to the power side, the gray to the alarm side.</TD></TR></TABLE>
Wow man thanks lot again. I was thinking the power go direct to separate sources. I'll try it when I get a chance. Also, I read on cause of an alarm to put the blue on the hoodpin trigger wire. Maybe you read it as I hooked it up to the pin itself, sorry.
Old Feb 6, 2008 | 10:45 PM
kweezerkwee's Avatar
do i have to use diode if im just adding a bb without any extra sensor?
Old Feb 7, 2008 | 06:24 AM
White Smoke's Avatar
i my honda
Global Mod
Default Re: (kweezerkwee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kweezerkwee &raquo;</TD></TR><TR><TD CLASS="quote">do i have to use diode if im just adding a bb without any extra sensor?</TD></TR></TABLE>
If it's going to a dedicated input on the alarm then no you do not.
scottso990
Audio / Security / Video
Apr 4, 2010 06:35 PM
MantisX
10
Sep 1, 2009 11:11 AM
theeogflip
May 5, 2008 09:45 PM
sniggler316
10
Nov 2, 2007 05:47 PM
icedaccord19
Feb 1, 2004 04:12 AM
