radio not on constanly
Old May 6, 2005 | 12:00 PM
ap716's Avatar
Default radio not on constanly
so my cd player goes off majority of the time and i was wonder if there was any possible way to make it stay on all the time. i've checked all of my wires already so i dont know what the problem is. could someone help me.
Old May 7, 2005 | 12:06 AM
Daedus's Avatar
Default Re: radio not on constanly (ap716)
It stays on for a while and then turns off for a while and then comes back on without you doing anything? I had a customer with that problem back when I was doing car audio. It was hard to diagnose but it turned out to be his grounds. My advice would be to start by re-wiring all the grounds (power & speaker) on the deck with proper gauge wire.
Old May 7, 2005 | 12:20 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ap716 &raquo;</TD></TR><TR><TD CLASS="quote">so my cd player goes off majority of the time and i was wonder if there was any possible way to make it stay on all the time. i've checked all of my wires already so i dont know what the problem is. could someone help me. </TD></TR></TABLE> Need more info, when does it "cut out"? when you play it loud, when you go over bumps or any time? How do you get it to come on again? 94
Old May 7, 2005 | 01:34 PM
numbnuts22715's Avatar
mine used to do that, and then one day it stopped working completely and didnt ever come back on... it started smoking and all this otehr crazy stuff... pretty weird.
Old May 7, 2005 | 08:27 PM
ap716's Avatar
Default Re: radio not on constanly (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> Need more info, when does it "cut out"? when you play it loud, when you go over bumps or any time? How do you get it to come on again? 94</TD></TR></TABLE>
the cd player goes off automatically. like i just listen to it then then i the player kinda blinks goes off then comes on then back off completely.
i dont do nothing for it to come back on. it just comes back on automatically. sometimes when it does come back on i kinda hear like a static noise. like the cd player trying to start back up.
Old May 8, 2005 | 06:21 AM
fcm's Avatar
fcm
Old Fart
i dont do nothing for it to come back on. it just comes back on automatically. sometimes when it does come back on i kinda hear like a static noise. like the cd player trying to start back up. </TD></TR></TABLE> One more thing, you keep saying "cd player" is it just the cd that cuts in and out, or does the radio do it also? when it cuts out, do all the lights on the HU go out, like when the HU is off?
If the cd cuts out, but the the lights on the HU stay on, it may be a speaker or speaker lead shorting out and the protection circuit cutting in.
If everything cuts out, [including lights] the problem is in the power or ground connections, even a defective fuse or fuse mount.
One more thing, do you have an amp or amps, or do the speakers run off HU power? 94
Old May 8, 2005 | 07:38 AM
ap716's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> One more thing, you keep saying "cd player" is it just the cd that cuts in and out, or does the radio do it also? when it cuts out, do all the lights on the HU go out, like when the HU is off?
One more thing, do you have an amp or amps, or do the speakers run off HU power? 94</TD></TR></TABLE>
everything cuts out, [including lights]. ill double check the fuses again.
could it possibly be that the hu is crapping on me. therefore i have to purchase a new one?
Old May 8, 2005 | 08:37 AM
fcm's Avatar
fcm
Old Fart
</TD></TR></TABLE>Yes it could be the Hu, but I would check the connections first, and another thing to try is how well do the fuses fit in the fuseboxs, radio acc. is in the incar fusebox and radio memory, [constant] is in the engine bay fusebox, even if they look good. replace them, and then put a finger on top of the fuse and wiggle it in its "mount" see if that will cut the HU off and on. 94
super60
Audio / Security / Video
May 27, 2006 08:27 AM
UnionCity LS
Jan 18, 2005 01:48 PM
HAcEx01
Jan 17, 2005 05:14 PM
jamie_honda_08
Oct 22, 2004 09:57 PM
JDMflavor_EJ
11
May 25, 2004 10:24 AM
