alpine CDA-7875 cd changer?!?!!
Old Jan 17, 2005 | 12:32 PM
UnionCity LS's Avatar
Default alpine CDA-7875 cd changer?!?!!
so my reciver ate a cd and wont give it back. ive had this reciver for a few years now so im not mad. what i plan on doing is hooking up a alpine S601 cd changer to fix this problem, BUT i dont know what kind of adapter i need, the round one or square one?! thanks for the help.
Old Jan 17, 2005 | 10:02 PM
Default Re: alpine CDA-7875 cd changer?!?!! (UnionCity LS)
BUMMMMMMMMMMMMMP
Old Jan 18, 2005 | 07:21 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UnionCity LS &raquo;</TD></TR><TR><TD CLASS="quote">so my reciver ate a cd and wont give it back. ive had this reciver for a few years now so im not mad. what i plan on doing is hooking up a alpine S601 cd changer to fix this problem, BUT i dont know what kind of adapter i need, the round one or square one?! thanks for the help.</TD></TR></TABLE> First hit the reset button on the HU, to see if that will spit the CD out, Alpine only made one adpt. for their HU changer combos, older HU, [8pin din plug "round"] to the new changers. [ unilink "square"] you can still get the older style changers , [8pin din] get any info you need for Alpine at http://www.alpine.com 94
Old Jan 18, 2005 | 01:48 PM
noob with an RS's Avatar
the two appropriate CD Changer connectors for alpine CD changers are called either "AI-Net" or "M-Bus." depending on what connector your alpine head unit needs determines what cd changer you can use. but there ARE adapters. for example i have an alpine which has an AI-net connector output. and i have an alpine CD changer that has the "M-BUS" connector. i plan to buy the AI-net to M-bus adapter so that they will be complatible with each other. if you have a newer alpine, it is likely it is AI-net, while the older HU's use M-Bus.
thunderboy
Honda Civic (2006 - 2015)
Jul 13, 2010 04:01 AM
UCLA.lion
Audio / Security / Video
11
Nov 26, 2006 05:11 PM
97EK9hatch
Jan 12, 2005 08:14 PM
twobit
Jan 10, 2005 06:42 PM
civicguycivic
Jan 24, 2003 07:09 PM
