Q:wiring killswitch to hazard lights
Old Mar 20, 2010 | 06:06 PM
77777's Avatar
Default Q:wiring killswitch to hazard lights
i had this idea because my hazards dont work so the button is just there. and what better hiding spot than right out in the open? but im really useless with figuring this stuff out even though im sure its simple. have searched this a few times but if anyones done it i didnt see it posted.
i dont really like posting this out for public discussion, but even if it did catch on theives turning everyones hazards on looking for switches might be kind of funny.
Old Mar 20, 2010 | 06:14 PM
Weakbyyou's Avatar
Default Re: Q:wiring killswitch to hazard lights
shouldnt be hard. you would have to figure out if the switch is normally open or normally closed first then you could your starter wire to it in series or parallel depending on what the switch is.
Old Mar 23, 2010 | 02:59 PM
baller status's Avatar
If you do this, you will melt your hazard switch.
Second statement doesn't even make sense with the first.
Old Mar 23, 2010 | 05:46 PM
Weakbyyou's Avatar
you couldnt be more right. i think i was half asleep and on percocets, just had knee surgery, when i wrote that. could run a ground through the switch but thats really no help. an alarm with starter kill relay would be your first option.
Old Mar 23, 2010 | 11:39 PM
dohcvtak's Avatar
eh doable with a relay but starter kills are too easily bypassed especially with MT
Old Mar 24, 2010 | 08:51 AM
crazyboy's Avatar
i have my car with a kill witch using a very open spot that theives wouldnt think of, pm me for info
Old Mar 25, 2010 | 12:26 PM
pjean_07's Avatar
Make a killswitch on your fuel pump. Its very easy to do! on my ek the power was the yellow with green stripe wire.. and for sure dont forget the relay
Old Mar 26, 2010 | 02:55 PM
Weakbyyou's Avatar
yea, if you know what your doing its not hard to cut out a relay. theft rate has gone down dramatically in my area in the past 10 years. enough that i dont worry about it to much.
Old Mar 27, 2010 | 09:19 AM
fcm's Avatar
fcm
Old Fart
If the hazards do not work, it is most likely because the hazard switch is bad, although it could be because of a blown fuse.
If hazard switch is bad it will not work as a kill switch either, you will also have to keep in mind that the hazard switch is also your signal lights power switch.
Power, [switched] for your signal lights goes through the hazard switch, all the wiring for the hazards and signal lights is the same, [common] the only diff. is the power input to the hazard switch, it is a 12V constant, [hot at all times] for hazard lights and a 12V switched, [hot in run and start] for the signal lights.
There is only one "main" output from the hazard switch, it supplies either the constant hazard light power or the switched signal light power to the turn signal/hazard relay.
That does not mean that the hazard switch can not be used as a "phantom" kill switch, but the switch has to be working. 94
Old Mar 28, 2010 | 05:43 PM
PyroProblem's Avatar
Get a repair manual or some wiring diagrams. You can get pretty creative in a car with momentary switches,clutch switches, main relay switches,fuel pump ground switches, etc.
On mine I wired the horn up to the starter so if a certain button/switch isnt pushed, the horn blares. Dont forget to use a diode or else youll start your car with the horn, LOL.. Im also using the anti-theft feature in Neptune.
Old Mar 30, 2010 | 05:01 PM
You can even wire the airbags to go off if another switch isnt pushed...
Death to thieves!
Old Apr 1, 2010 | 05:17 PM
You could use any old switch to control a relay. But you would never run the starter wire through a switch. It would have to be a big high amp switch but that would be stupid.
tallguy21
Jul 21, 2013 11:18 AM
Delano Devine
Honda Civic (2001 - 2005)
Mar 21, 2009 07:41 PM
eskimo10
Audio / Security / Video
Dec 29, 2008 11:31 AM
BlazinITR
Jan 24, 2003 01:05 PM
Ham'ed Hatch
Jan 7, 2003 11:14 PM
