Python 880xp
Old Nov 9, 2008 | 10:26 PM
TurboTeG4's Avatar
Default Python 880xp
Today my remote seems to work and have communication with my car to unlock doors, remote start and everything but on the display the padlock doesnt go into the locked position. It beeps a extra time and shows a vertical line on the display or something. Is this my transmittor thats bad?
Old Nov 10, 2008 | 05:40 AM
fcm's Avatar
fcm
Old Fart
Default Re: Python 880xp (TurboTeG4)
Where did you get the system from? 94
Old Nov 11, 2008 | 04:25 PM
TurboTeG4's Avatar
Default Re: Python 880xp (fcm)
Was on my car when I bought it 5 years ago
Old Nov 11, 2008 | 07:33 PM
KRock459's Avatar
The remotes go bad frequently, just takes a small drop. If your feeling fearless, here is how to fix it, just takes some soldering skill....
There is a small phillips screw behind the battery cover, remove it and you can seperate the remote case. Inside, you will see two PC boards, one with the antenna and the other with the buttons/display. You will see a 3 pin connector on top and a four pin on bottom connecting the two boards, inspect them and you will find a broken solder joint (usually the upper 3 pin connector) . Repair the contact with a soldering iron. This solves about 75% of the issues I have had when you loose receiving com. from the alarm.
Good luck
Kirk R
Old Nov 12, 2008 | 09:53 AM
TurboTeG4's Avatar
Default Re: Python 880xp (KRock459)
Ok I opened it up 3 pin and 6 pin connector I seperated it but it looks ok, my remote communicates with my car but the lock picture on my remote stays unlocked and shows a horrizontal line with a ball on top when I use it
(The signal icon will be displaed if a command is transmitted to the vehicle but a command page is not received.)
Modified by TurboTeG4 at 7:00 PM 11/12/2008
Old Nov 12, 2008 | 08:48 PM
KRock459's Avatar
Its very hard to see the break in the solder contacts, I would try to hit them with a soldering iron. When you see the icon at the top (line with a ball), it is the antenna icon, if you get three beeps followed by the antenna icon, it indicates out of range or no signal received.
It could just be a bad remote, wouldnt be the first.
Kirk R
Old Nov 15, 2008 | 01:52 PM
TurboTeG4's Avatar
How do you program the new remote to my car?
Old Nov 30, 2008 | 10:06 PM
TurboTeG4's Avatar
Anyone know how to program new remote?
Old Dec 8, 2008 | 05:05 PM
TurboTeG4's Avatar
Well bought a new remote for 80.00 and same thing command page not received, what else can I look into as im very unfamiliar with alarm systems.
Old Dec 9, 2008 | 05:13 AM
fcm's Avatar
fcm
Old Fart
http://www.directeddealers.com/manua...G554P_7-02.pdf
Programing a transmitter should be the same as most DEI units,
1- open door.
2- turn ign. on.
3- press and release valet/program button one time, siren will chirp one time and LED will blink one time.
4- press and hold valet/program button.
5- press and release lock/arm button on remote, siren will chirp one time.
6- release valet/program button, turn off ign., your done. 94
Old Dec 9, 2008 | 04:44 PM
TurboTeG4's Avatar
I can program it but, its doing the same thing as the transmitter im replacing
Old Dec 9, 2008 | 05:29 PM
fcm's Avatar
fcm
Old Fart
Then the remote was not the problem, has your unit got a page notification on/off??94
Old Dec 17, 2008 | 10:56 PM
TurboTeG4's Avatar
I tried messing with options, page vibrator and buzzer and what not , same thing. Could this be the module that sends the page to my remote not working. Is this replaceable?
Old Dec 18, 2008 | 01:42 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
If this is not the isssue. And you tried a new remote. I putting my money on the brain not sending out page alerts. Send It back to dei and have them fix it
Old Dec 21, 2008 | 02:06 PM
TurboTeG4's Avatar
Ok ill send it in for repairs, I doubt my car will run without this right? Its hooked up to remote start
paysonsjlow
Audio / Security / Video
Jan 20, 2009 04:39 PM
HONDRETTI
May 30, 2008 07:56 PM
evo1234
May 13, 2006 01:27 PM
WreckedTeggie
Nov 19, 2005 10:34 AM
ginoboy1978
Oct 12, 2005 09:07 AM
