Compustar remote problems
Old Oct 11, 2005 | 06:30 AM
ginoboy1978's Avatar
Default Compustar remote problems
Well i bought a compustar unit off my friend for $100.
Model: Compustar 2WFMR (Two way FM remote)
Sometimes my remote will act up and start to play a 'song'?? Usually happens when i try to arm or disarm the vehicle. I have to wait until the 'song' ends before i can go ahead and arm/disarm the car. Does this mean the battery is about to die?
Also, can i shut off the shock sensor or adjust is to be less sensitive. This morning a school bus drove by my house and set off my alarm......thats ridiculous.
Anyways, any help would be appreciated.
Sidenote: My LCD screen doesn't work so i cant tell what functions are on or off. I guess thats what i get for $100.
Thanks.
DAN
Old Oct 11, 2005 | 09:30 AM
fcm's Avatar
fcm
Old Fart
Default Re: Compustar remote problems (ginoboy1978)
It sounds like the remote is powering up, try this, remove the batt. wait a sec. then replace the batt. if the sound you hear is the same, then it could be a low batt. or more then likely a poor connection of the batt., is the batt. loose in it's spot, try replacing the batt. with a new one, [use a good quality batt.] and make sure it is a snug fit, [terminals in remote make good solid contact with the batt.] I have run into this once or twice all I did was "bend" the batt. term at the bottom of the remote "out" a little so it made better contact with the batt.
The Impact sen. adjustment in right on the impact sen. itself, FYI very small adjustments will make a diff. it is a two stage impact sen., [warn a way, soft impact and full alarming on hard impact.
BTW 2WFMR is the model number of the remote , the impact sen, adjustment is the same on all models http://www.staub.ca/tech/Manua...l.pdf to check the sensitivity, arm the alarm, wait 15-20 sec. then "tap" windshield with side of fist, start softly and get harder till the alarm triggers "warn a way" then harder till alarm goes into full alarm mode, don't forget. you will not be able to transmit disarm untill alarm has stopped paging the remote, it will take a few sec., also the first disarm comand the alarm "sees" will only turn off the siren, you will have the disarm a second time to disarm the alarm. 94
Old Oct 11, 2005 | 10:47 AM
Default Re: Compustar remote problems (fcm)
^^Thanks for the great feedback. I will try out your suggestions.
DAN
Old Oct 11, 2005 | 04:50 PM
Hey fcm, I pm'd you.
When i turn off the shock sensor what symbol/icon will be displayed on the remote so i can tell if the shock sensor is off.
Please advise, thanks guys.
DAN
Old Oct 12, 2005 | 09:07 AM
fcm's Avatar
fcm
Old Fart
UB "IMed" 94
Si_chRis
Audio / Security / Video
11
Jan 26, 2009 04:55 PM
Osiris94EJ
19
Oct 31, 2007 01:11 PM
EeeJayEight
Jun 4, 2007 01:22 PM
Jago
May 14, 2006 11:53 PM
riceburnerryan
Feb 14, 2006 08:05 PM
