python 1090 sensor bypass question
Old Oct 1, 2009 | 02:26 PM
zsudz922's Avatar
Default python 1090 sensor bypass question
on my system im going to have the glass brake sensor, tilt sensor and a AU94T. im also installing window modules and trunk popper.
so my question is does the python 1090 automatically bypass the sensors when using the trunk popper or the window modules through aux channels?
Old Oct 2, 2009 | 06:20 AM
fcm's Avatar
fcm
Old Fart
Default Re: python 1090 sensor bypass question
Most DEI alarms disarm when "trunk pop" is used, but not if other EXT outputs are used and sensors are not bypassed, they should not need to be bypassed if using window control, a proximity sensor "sees" through glass and impact sensitivity is set too high, [or improperly installed] if triggered by window movement. 94
Old Oct 2, 2009 | 07:52 AM
zsudz922's Avatar
ok, cool. the directions say if you have a proximity sensor to wire it to a relay so when you roll down the windows it bypasses the sensor. so i should be fine without bypassing the sensor at all?
Old Oct 2, 2009 | 03:53 PM
fcm's Avatar
fcm
Old Fart
I have never installed a relay for that, and I have done more then a few alarms with proximity sensors and window modules, I have an Alpine alarm with a dual stage "radar" sensor in my 94LS and I can roll the windows down without any problems, [module is a DEI 530T].
Install it without the relay, if there is a problem, add the relay. 94
Old Oct 2, 2009 | 07:08 PM
zsudz922's Avatar
ok, thanks! what do you think about the sunroof though? im putting a 530t for my front windows and a 529t for my sunroof.
Old Oct 5, 2009 | 03:39 AM
fcm's Avatar
fcm
Old Fart
The sunroof can be an issue, [PITA] on some Honda/Acura. 94
Old Oct 5, 2009 | 06:14 AM
zsudz922's Avatar
an issue with setting off the alarm?
Old Oct 6, 2009 | 12:08 PM
fcm's Avatar
fcm
Old Fart
Roofs with both slide open and tilt on same switch, [open, close/tilt] will tilt if already closed, a timer and relays may be needed.
So questions are, MM&Y of car and what kind of sun roof switch is in the car and what will sun roof do?94
Old Oct 6, 2009 | 12:58 PM
zsudz922's Avatar
honda(of course)lol prelude 1996. i did my research and i shouldnt have that problem. my sunroof is the over roof one. i just have open and close switch. so when i hit "open" it will vent up and start moving back. when i hit "close" it will just close and stop. i have to hold the button down for it to open or close though.
Old Oct 7, 2009 | 05:57 AM
fcm's Avatar
fcm
Old Fart
Then the 529T will work, you should not need anything but the 529T. 94
Old Oct 7, 2009 | 07:59 AM
zsudz922's Avatar
ok, cool. and do you think that will be a problem with the au94t? for any reason?
Old Oct 7, 2009 | 12:09 PM
fcm's Avatar
fcm
Old Fart
It may be because of metal framing, tracks and so on, but again I have never needed a relay, it is easy enough to add the relay if needed. 94
Old Oct 7, 2009 | 12:22 PM
zsudz922's Avatar
ok. thanks for all your help, i really appreciate it.
The G2 Racer
Audio / Security / Video
Mar 10, 2009 02:36 PM
Got Utensils
Apr 20, 2007 10:52 AM
Spence
Feb 6, 2004 10:50 PM
swatdog
Jan 13, 2004 11:51 PM
gumbii
Feb 16, 2003 08:51 PM
