python 1090 sensor bypass question
on my system im going to have the glass brake sensor, tilt sensor and a AU94T. im also installing window modules and trunk popper.
so my question is does the python 1090 automatically bypass the sensors when using the trunk popper or the window modules through aux channels?
Most DEI alarms disarm when "trunk pop" is used, but not if other EXT outputs are used and sensors are not bypassed, they should not need to be bypassed if using window control, a proximity sensor "sees" through glass and impact sensitivity is set too high, [or improperly installed] if triggered by window movement. 94
ok, cool. the directions say if you have a proximity sensor to wire it to a relay so when you roll down the windows it bypasses the sensor. so i should be fine without bypassing the sensor at all?
I have never installed a relay for that, and I have done more then a few alarms with proximity sensors and window modules, I have an Alpine alarm with a dual stage "radar" sensor in my 94LS and I can roll the windows down without any problems, [module is a DEI 530T].
Install it without the relay, if there is a problem, add the relay. 94
Roofs with both slide open and tilt on same switch, [open, close/tilt] will tilt if already closed, a timer and relays may be needed.
So questions are, MM&Y of car and what kind of sun roof switch is in the car and what will sun roof do?94
honda(of course)lol prelude 1996. i did my research and i shouldnt have that problem. my sunroof is the over roof one. i just have open and close switch. so when i hit "open" it will vent up and start moving back. when i hit "close" it will just close and stop. i have to hold the button down for it to open or close though.
gumbii
Audio / Security / Video
Feb 16, 2003 08:51 PM
