A problem with my system.
Old Mar 23, 2009 | 10:28 AM
Fantastic420's Avatar
Default A problem with my system.
I had my system hooked up a while ago and was working fine. I took it out for a few, then wired it back together. I found out the sub wire inside was ripped off. I put a different sub in there. When I put the key in, Amp goes green, then makes a bass hit then goes red. I dont know what the problem could be. I checked everything, fuses, a few ppl checked the wiring. Could it be my remote wire in my cd player being loose or anythin because when I touch it it starts to make the bass noise, etc..
thanks
Old Mar 26, 2009 | 08:42 AM
dj-t's Avatar
Default Re: A problem with my system.
Did you check the resistance/ohms on the sub it may be to low for your amp to handle
98civdx
Audio / Security / Video
Jan 3, 2012 09:12 PM
Import_spoon
Feb 21, 2007 12:59 PM
stackz
Oct 17, 2006 01:12 PM
jerm001
Apr 18, 2004 08:48 PM
beef3000
May 28, 2003 05:18 PM
