amp problem
Old May 28, 2003 | 12:11 AM
beef3000's Avatar
Default amp problem
I am tryin to install a mtx amp in my 98 prelude. I have intalled stereo systems many times and never encountered a problem such as this. I cant get my amp to turn off!. its properly connected the the remote wire and as far as I know its grounded well. the funny thing is, that the amp doesnt get power unless I connect the RCA cables. as soon as I disconnect the rca cables, it turns off. I'm pretty sure its not a problem with the equipment because I had all the same equipment installed in my old car about a week ago and everything worked fine. any help would be much appreciated. thanks.
Old May 28, 2003 | 12:59 AM
Bigphlip's Avatar
Default Re: amp problem (beef3000)
You must have wired the remote wire to a constant 12v. Make sure it's not. This should help.
Old May 28, 2003 | 05:07 AM
Xsi's Avatar
Xsi
Use a test light and check to see if the remote wire is turning off when it's supposed to.
If the remote wire is turned off and the amp is still on then something is odd with your wiring or the amp
Old May 28, 2003 | 05:18 PM
CustomCJ00's Avatar
If the amp shuts down when you unplug the rca's then you have no ground.
the amp is grounding through the shield on your rca's . that is why it is acting funny.
98civdx
Audio / Security / Video
Jan 3, 2012 09:12 PM
ef_88_hatch
13
Sep 13, 2008 12:53 PM
notguilty411
15
Apr 5, 2005 01:56 PM
SIReg9
15
Mar 8, 2004 06:18 PM
brickonwheels
Jan 12, 2004 09:33 PM
