Weird amp/deck problem
Old Apr 18, 2004 | 07:50 PM
jerm001's Avatar
Default Weird amp/deck problem
I just installed my amp and sub (480 watt explode, 10" pioneer sub) everthing worked fine for about 5 minutes and then I started having this problem. When the deck is on radio as a source, the amp turns on (green light) but no sound will come from the sub, when I change the source to cd, the amp shuts off, and the cd deck thinks that there is no cd in (there is) and it won't eject it.
Keep in mind, before I hooked all this up everthing worked fine, including the deck
If anyone has any clue as to what may be causing this please let me know, I am completely baffeled.
Thanks
Old Apr 18, 2004 | 08:44 PM
DELTEGRA's Avatar
Default Re: Weird amp/deck problem (jerm001)
first check your amp turm on wire. It should be a blue or a blue white off of the deck. This wire should have roughly 12 volts when the deck is on (with source being cd or radio). If the wire looses power when you switch from radio to cd source then you have hooked to the wrong wire, that is power antenna not amp turn on! If you have no clue, then just hook your wire from your amp (amp turn on) to the red wire off of the deck (keyed power). hope this helps!!
Old Apr 18, 2004 | 08:48 PM
jerm001's Avatar
I know it is hooked up to the right wire. the thing is after I got it hooked up everything worked fine for about 5 minutes, and then for some reason went to crap
plus the amp turns on when on radio, but nothing plays from the speakers it is hooked up to
Maleek
Audio / Security / Video
Jul 23, 2009 05:19 AM
MilanoCivic97
10
Mar 26, 2007 09:37 PM
Import_spoon
Feb 21, 2007 12:59 PM
loup05
Oct 10, 2005 12:32 PM
92-LS-Civic
Oct 7, 2005 09:06 AM
