picture request: amp settings
Old Jul 23, 2004 | 09:43 AM
ieatrice's Avatar
Default picture request: amp settings
i've been playing around with my amp settings for my sub and i can't get it to give me that clean hard hitting bass sound. this may seem weird, but can someone post a picture of your amp settings? i know it all depends on your set up, but i just want an idea. btw, i'm running a jl 12w6 with 1200 watt amp
Old Jul 23, 2004 | 11:28 AM
spark plugs.
Guest
Posts: n/a
Default Re: picture request: amp settings (ieatrice)
1. turn the radio volume 75% up.
2. turn the amp gain up untill you hear distortion
3. back down a little bit until right before the distortion
4. set the frequency at 63 hz
5. adjust until the bass sounds right.
*to hardcore audiophiles*: yes, yes, i know that isn't the perfect way to tune an amp...but that should help him get around the right range he wants.
Old Jul 23, 2004 | 03:10 PM
ieatrice's Avatar
Default Re: picture request: amp settings (spark plugs.)
thanks! one more question.. should i leave my deck's eq on flat?
Old Jul 23, 2004 | 03:15 PM
EBP_SI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ieatrice &raquo;</TD></TR><TR><TD CLASS="quote">thanks! one more question.. should i leave my deck's eq on flat?</TD></TR></TABLE>
for setting your gains, yes.
Old Jul 23, 2004 | 03:16 PM
spark plugs.
Guest
Posts: n/a
Default Re: picture request: amp settings (EBP_SI)
it really depends on how your system is setup and what your equipment is. i use my alpine head unit to adjust the sound to my interiors, so i set the eq on the deck first...then i adjusted my amp. what's your setup?
Old Jul 23, 2004 | 03:20 PM
ieatrice's Avatar
i'm running 2 performance teknique amps.. one 4 ch 800 watt powering my front and rear speakers, and one 2 channel 1200 watt powering my 12" jl w6. i have a jvc cd/mp3 deck.
Old Jul 23, 2004 | 03:22 PM
spark plugs.
Guest
Posts: n/a
what kind of outputs does the h.u. have? f/r/s or just f/r?
Old Jul 23, 2004 | 09:12 PM
ieatrice's Avatar
front, rear, sub
Old Jul 25, 2004 | 10:35 PM
PupaScoopa's Avatar
You can also check with a local audio shop and see what they can do on a "baseline" adjustment or even on an in-depth adjustment with an RTA meter.
peter96ek
Audio / Security / Video
May 1, 2008 12:46 PM
GoLowDrew
17
Mar 22, 2008 06:59 AM
macdaddydelux
Aug 23, 2007 11:01 PM
Importn2oRacer
13
Jun 14, 2007 04:45 PM
tca0bell
Nov 15, 2004 07:18 PM
