1200Watt Amp question
Old Jun 11, 2007 | 09:16 PM
Importn2oRacer's Avatar
Default 1200Watt Amp question
I have a single 1200Watt amp connected and powering my two 12in. subwoofers. The subs can handle 1300watts max each. Anyways my question is are each of the subwoofers recieving 1200watts of power or no?
P.S. the RMS on the subs are 600watts each w/e that is.. sorry im a noob at this stuff.
Old Jun 11, 2007 | 10:30 PM
mrdeadman's Avatar
They let me pick
Default Re: 1200Watt Amp question (Importn2oRacer)
whats the rms rating on the amp as well as specs on the subs?
Old Jun 12, 2007 | 07:47 AM
Hcivic88's Avatar
Default Re: 1200Watt Amp question (mrdeadman)
k, well the way I see it, you have two 1300W subs, so for the two of em u have 2600Wmax. The amp pushes 1200Wmax. So the way I see it, your only getting about half the power your subs are able to take. I cant remember the calculation for RMS right now, its been a while for me, but for a rough estimate, your subs are 600 rms and 1200 max, meaning ur amp should be somewhere about 600rms or so I would guess.
Old Jun 12, 2007 | 10:59 AM
mrdeadman's Avatar
They let me pick
Default Re: 1200Watt Amp question (Hcivic88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hcivic88 &raquo;</TD></TR><TR><TD CLASS="quote">k, well the way I see it, you have two 1300W subs, so for the two of em u have 2600Wmax. The amp pushes 1200Wmax. So the way I see it, your only getting about half the power your subs are able to take. I cant remember the calculation for RMS right now, its been a while for me, but for a rough estimate, your subs are 600 rms and 1200 max, meaning ur amp should be somewhere about 600rms or so I would guess.</TD></TR></TABLE>
Max power doesn't mean ****.
Old Jun 12, 2007 | 11:56 AM
01d17's Avatar
rms is the true power your subs can handle and amp puts out. it means root mean square. if each sub is 600w rms, then you more then likely need a larger amp. is it a sony 1200w cause i get that all the time " yo i got that 1200w sony" even though its rms is 500x1 at 4 ohms. if it is the 2 channel you can only run one of these subs safely
Old Jun 12, 2007 | 01:49 PM
jz98ctr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Importn2oRacer &raquo;</TD></TR><TR><TD CLASS="quote">I have a single 1200Watt amp connected and powering my two 12in. subwoofers. The subs can handle 1300watts max each. Anyways my question is are each of the subwoofers recieving 1200watts of power or no?
P.S. the RMS on the subs are 600watts each w/e that is.. sorry im a noob at this stuff. </TD></TR></TABLE>
what brand of equipment are you using???
Old Jun 13, 2007 | 06:43 AM
Cfitz87's Avatar
Default Re: 1200Watt Amp question (jz98ctr)
I wish i under stood this stuff more. Do you guys no of any links that have information about rms and all car audio information. My email is Cfitz87@comcast.net
Old Jun 13, 2007 | 08:52 PM
Default Re: 1200Watt Amp question (Cfitz87)
Found out 2day my amps have 600watt rms also
Old Jun 14, 2007 | 05:15 AM
jz98ctr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jz98ctr &raquo;</TD></TR><TR><TD CLASS="quote">
what brand of equipment are you using???</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jz98ctr &raquo;</TD></TR><TR><TD CLASS="quote">
maybe now you can answer
Old Jun 14, 2007 | 05:16 AM
jz98ctr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cfitz87 &raquo;</TD></TR><TR><TD CLASS="quote">I wish i under stood this stuff more. Do you guys no of any links that have information about rms and all car audio information. My email is Cfitz87@comcast.net</TD></TR></TABLE>
there are a few stickied threads at the top of this forum that have some good information in them. there are also a few other good sites with good info too but i can't think off the top of my head right now.
http://www.installdr.com has some good info
Old Jun 14, 2007 | 05:46 AM
fcm's Avatar
fcm
Old Fart
I have to agree with jz98ctr what the hell is the make and model of the amp and subs???????
It can't be a secret, spit it out. 94
Old Jun 14, 2007 | 07:53 AM
Default Re: 1200Watt Amp question (fcm)
LOL a secret?? Its nothing big it came with the car when I bought it. Sony Xplods amp n subs. (1) 1200Watt amp and (2)12" subs both 600rms power. I heard a lot of people saying "oh thats a piece of s*&$" and stuff but honestly after seeing other aftermarket systems mine acutally kicks in harder bass wise.
Old Jun 14, 2007 | 02:17 PM
jz98ctr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Importn2oRacer &raquo;</TD></TR><TR><TD CLASS="quote">Anyways my question is are each of the subwoofers recieving 1200watts of power or no? </TD></TR></TABLE>
no
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Importn2oRacer &raquo;</TD></TR><TR><TD CLASS="quote">Sony Xplods amp n subs. (1) 1200Watt amp and (2)12" subs both 600rms power. I heard a lot of people saying "oh thats a piece of s*&$" and stuff but honestly after seeing other aftermarket systems mine acutally kicks in harder bass wise.</TD></TR></TABLE>
see now that wasn't so hard was it???
they are not TOTAL junk but there is definitely better product to be had that does not mislead you into thinking you have more juice than you actually have.
that sony xplod amp you have is not gonna put out 1200 watts unless it's ALS
ALS=As Lightning Strikes and comes down to Earth and hits the heatsink of your amp.
you might actually get 1200 watts outa that Sony amp IF and only IFyour cars' electrical system is putting out 14.4V+ constantly AND running your subs at around 1KHz or higher which would essentially negate the entire point of having subs altoghter because they shouldn't be playing any frequencies even close to that...unless you really hate those subs and are trying to fry them.
Old Jun 14, 2007 | 04:45 PM
fcm's Avatar
fcm
Old Fart
that's not a model number, the model number will start with an XM-****. 94
m.glisson003
Audio / Security / Video
18
Aug 15, 2011 06:17 PM
freeagent
Jul 4, 2009 09:49 AM
supracrx
Feb 26, 2008 06:06 AM
supracrx
13
May 25, 2006 12:40 PM
IDriveHonda
18
Oct 9, 2003 05:43 PM
