amp & sub set up
Old Aug 21, 2007 | 06:09 PM
macdaddydelux's Avatar
Default amp & sub set up
i have a infinity 12" sub in a ported box that my friend gave me..he only had like 350watts on it but i enventually wanna upgrade so i was thinkin i could go ahead & get like a 1200watt amp & turn it down untill then..do u think this would be ok????
Old Aug 21, 2007 | 06:21 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: amp & sub set up (macdaddydelux)
why are you trying to send that much power to a speaker that does not needed it.
Old Aug 22, 2007 | 12:35 PM
johnson_n's Avatar
Default Re: amp & sub set up (wrx-killer-Sti-eater)
Yes it would be OK. When you say 1200W, is that RMS? What voice coil configuration is the current subwoofer? Be sure to set the gains correctly and not to send a clipped signal.
Old Aug 22, 2007 | 12:47 PM
8520's Avatar
Default Re: amp & sub set up (johnson816)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnson816 &raquo;</TD></TR><TR><TD CLASS="quote">Yes it would be OK. </TD></TR></TABLE>
Arguable. What if that infinity is only a 150rms speaker? Would you still be ok sending it 1200rms? I, for one, wouldn't do that with an infinity product.
Old Aug 22, 2007 | 03:35 PM
Default Re: amp & sub set up (misanthropist)
im eventually gonna get jl audio w6's so i was gonna just go ahead & get an amp big enough 4 RIGHT NOW, then when i get the w6's i can just turn the amp up & be good
Old Aug 22, 2007 | 03:41 PM
99fbpem1's Avatar
infinity subs blow really easy, and if it's ported, it doesn't need a lot of power. I would just buy the amp, let it sit until you can afford the jl's and then sell your old set up.
Old Aug 23, 2007 | 06:30 AM
johnson_n's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by misanthropist &raquo;</TD></TR><TR><TD CLASS="quote">
Arguable. What if that infinity is only a 150rms speaker? Would you still be ok sending it 1200rms? I, for one, wouldn't do that with an infinity product.</TD></TR></TABLE>
Just because an amp is rated 1200w doesnt mean it's putting out full power all the time.
Need more info from the OP about what the current Infinity subwoofer and future amp will be.
Old Aug 23, 2007 | 04:11 PM
HAB22's Avatar
I highly doubt that the amp you want to get is 1200 rms power. It is probably 1200 peak and like 3 or 400 rms. So you probably wouldn't blow it but just don't bump it too much.
Old Aug 23, 2007 | 04:15 PM
HAB22's Avatar
And b4 you buy your new subs you wana make sure that the rms on the amp matches or is a little greater than the wattage of the subwoofers or they won't be hitting very hard. Just forget the peak power that doesn't mean jack.
Old Aug 23, 2007 | 11:01 PM
RickyBizee's Avatar
yes thats fine...he clearly said would it be ok to buy a 1200 watt amp and turn it down....yes you can do that....just tune it to where the sub is looking like its getting a nice pulse and not hammering the hell out of itself.
either way, if you tune the amp right to the sub it wont blow, and most likely like johnson816 said its probably not 1200 watts rms thats probably the max.
teknoracing
Audio / Security / Video
30
Jun 7, 2006 03:42 PM
silentblackhat
Dec 28, 2005 11:58 AM
AznImage504
Aug 30, 2004 06:00 PM
icechimpe
Apr 25, 2004 05:02 PM
AaronJ
Apr 1, 2004 01:10 PM
