?????OHMs???????
Old Apr 23, 2002 | 12:16 PM
sleeperaccordv6's Avatar
From: west Ft.Worth, Texas, the big one in the center
Default ?????OHMs???????
Ok say if you have an amp that can be bridged @ 4OHMs
and two 12"s that are rated w/ dual 4OHM voice coils is there
any way to hook it up.
sorry for the vauge dis. just tell me if you need more info....
Thanks,
Old Apr 23, 2002 | 06:57 PM
SIRX's Avatar
Default Re: ?????OHMs??????? (01sleeperaccord6)
Thanks,
So you have dvc subs? if so are they 4 or 2 when both hooked up?
Old Apr 23, 2002 | 08:16 PM
Malachi's Avatar
Default Re: ?????OHMs??????? (SIRX)
should be 4, 4 ohm coils total, so either 1 ohm or 4 ohm. wire the coils in series and the speakers in parrallel for 4 ohms.
Old Apr 24, 2002 | 06:56 AM
Default Re: ?????OHMs??????? (Malachi)
Yep you are totaly right(Malachi) I spoke
to an audio install friend and he said the exact same thing.
thanks for the imput...
Old Apr 24, 2002 | 02:39 PM
nsxxtreme's Avatar
The bridged amp will actually only see 2 ohms. So I hope your amp is 2 ohm stable. Good luck.
Old Apr 24, 2002 | 03:13 PM
Malachi's Avatar
Default Re: ?????OHMs??????? (nsxxtreme)
how would you recommend he wire them?
[Modified by Malachi, 6:19 PM 4/24/2002]
Old Apr 24, 2002 | 08:17 PM
nsxxtreme's Avatar
He doesn't really have many options on how to wire them. Just wanted to inform him that if the amp says that it is 4 ohm stable bridged. It doesn't neccessarily mean he can hook up a 4 0hm load to it. Check your amplifier specifications.
I think the question that needs to be asked is what kind of amp does he have?
Bridgeing the amp to these speakers may not be the best solution.
It may turn out to be fine, but more info is needed to answer his question accurately.
Old Apr 24, 2002 | 09:41 PM
Malachi's Avatar
ok, just hoping i didnt mislead him, thanks
Old Apr 26, 2002 | 05:16 AM
nsxxtreme's Avatar
If anyone is interested in the math here it is just use any combination
For series R1+R2+R3....+Rn=Req
For parralel
1/(1/R1+1/R2+1/R3.....+1/Rn)=Req
Req= equavilant impedence
R1....Rn= The impedence of each voice coil.
ReV LiMiT
Audio / Security / Video
Mar 12, 2006 02:41 PM
civichatchb18c
Dec 19, 2004 08:47 AM
bradykiller
Mar 31, 2004 06:48 PM
dpmac10
Sep 27, 2003 02:56 AM
mstewar
Sep 10, 2003 06:54 PM
