amp and sub install ????????
Old Dec 16, 2004 | 03:13 PM
civichatchb18c's Avatar
Default amp and sub install ????????
please post step by step sub install 2450 watt subs with a 400 watt 2ch amp at 4ohm
Old Dec 17, 2004 | 04:25 PM
b18cinmycrx's Avatar
Default Re: amp and sub install ???????? (civichatchb18c)
step by step hu u know how long that will take someone it will be faster to actually do it than for me to sit here and tell u how is done but i hope someone helps u
Old Dec 18, 2004 | 01:26 AM
just skim over the important stuff and basic hook up
Old Dec 19, 2004 | 08:47 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civichatchb18c &raquo;</TD></TR><TR><TD CLASS="quote">please post step by step sub install 2450 watt subs with a 400 watt 2ch amp at 4ohm</TD></TR></TABLE>Need more info, what kind of subs what ohms on the subs VCs, if they are 4ohm VCs the only way for the amp to see a 4ohm load is to wire one sub to each channel of the amp, if you parallel the subs VCs it's a 2ohm load and the amp will not be stable at 2ohms in mono, if you wire the subs VCs in series you have an 8ohm load, and that is ok for the amp in mono, but it cuts the output of the amp in half. so the info we need is
1- what is the ohms of the subs voice coil, and is it a SVC or DVC
2- what is the continuas power handeling of the sub, [not peak power]
3- what is the RMS power of the amp. [ again not the peak output power]
let us know 94
superdat1
Audio / Security / Video
13
Jan 4, 2008 10:42 AM
JdM_RACeR07
Nov 19, 2006 04:02 PM
integra-modder
Jan 1, 2003 02:24 PM
Vp Special K
Sep 30, 2002 09:56 PM
sleeperaccordv6
Apr 26, 2002 05:16 AM
