need sub amp recommendations
Old Aug 13, 2007 | 12:19 AM
  #76
thekid03's Avatar
Default Re: (camusmuse)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by camusmuse &raquo;</TD></TR><TR><TD CLASS="quote">I'll agree with the short wire runs being good, but heat dissipation can be tricky. You have to be really careful that there is enough room above the amp, especially considering the bottom of the seat comes down with someone sitting in it. I've seen installs where the person was basically "sitting" on the amp.....not good. Even worse when they try to move the seat, can scratch the hell outta the amp. You need at least an inch . </TD></TR></TABLE>
my take on things is if you're amp is shutting down something is wrong. i guess my logic comes from server rooms....anyone constructing a server room from scratch would be insane to not install AC and depending on how much load each server 'sees' you'll have false-floors w/ AC vents cooling from ground up + top down.
wrong or right i use the same principle when it comes to my amps....the minute one of them shuts down i think to myself i'm not treating my amps as I should. the fans next to my amps are doing nothing more than blowing around a bunch of hot air. In the winter though they never go into protection mode.
one of these days I'll get off my lazy azz and start competing but one thing I've never seen is a competitor who has come up with a clever way of cooling amps. will it change SQ? maybe/maybe not. but at least it'd be it's original....
but also keep in mind this is coming from someone who doesn't belive in EQ and decided the best place for a 1/3 octave Arc EQ is my closet after playing around for the better part of a day with it in and out and in and out listening to all kinds of music.
Old Aug 14, 2007 | 02:26 PM
  #77
xXSilentScreamXx's Avatar
Default Re: (thekid03)
2500 watt old skool lanzar amps!!!
deeweezy
Audio / Security / Video
May 28, 2003 09:24 PM
L4NDO
Apr 26, 2003 08:01 PM
yoyoyo
Apr 15, 2003 06:54 PM
Calavera
17
Jun 24, 2002 10:30 AM
xJ.SLOTHx
Feb 14, 2002 11:12 PM
