need a redesign
Old 12-02-2002, 03:34 PM
RedDawg's Avatar
Default need a redesign
I want to re-design my trunk set up (in my integra) so that i can still partially use my trunk space but i still want it to look good. This is my current set up, its a pretty crappy shot but it should give you an idea of what equipment i need to relocate.
I'm open for any suggestions or pics of previously done setups. The equipment in the trunk is:
Rockford Punch 800a2
Rockford Punch 800a4
2 audiobahn 1 farad caps
Punch X crossover
large rockford style dist. block
theres currently 2 blue 15" neons up above the subs
I'd like to keep the blue neon effect but i want the tubes to still be hidden
Old 12-02-2002, 03:36 PM
how low's Avatar
Default Re: need a redesign (RedDawg)
The picture wasn't working but I'd say use all the equipment you have now, maybe changing or upgrading some stuff but learn to fiberglass and go crazy
Old 12-02-2002, 03:37 PM
RedDawg's Avatar
Default Re: need a redesign (how low)
hmm, here's an link to the picture. Hope this works
http://www.imagestation.com/picture/...c.jpg.orig.jpg
Old 12-02-2002, 03:39 PM
how low's Avatar
copy and paste that url, just don't click it..
That looks clean, you want to go crazy or just want something different?
[Modified by how low, 12:40 AM 12/3/2002]
Old 12-02-2002, 03:46 PM
RedDawg's Avatar
either, i'm open to all ideas. The spare tire is gone so i have the entire wheel well to work with if i want.
Old 12-02-2002, 04:20 PM
Hcivic88's Avatar
heres your pic
I say if you want to save space, try to make some sort of enclosure using the wheelwell and fiberglass, although for two subs, it'll be a bit more difficult but can still be done
[Modified by Hcivic88, 5:21 PM 12/2/2002]
Old 12-02-2002, 04:38 PM
RedDawg's Avatar
Default Re: need a redesign (Hcivic88)
the subs are a little too deep for putting em in the wheel well, they also recommend a 1.0 cu. ft. per sub so the wheel well is out. I could maybe use it for the amps.
Old 12-02-2002, 06:47 PM
clm_Sol's Avatar
Mount the amps and caps on the sides and fiberglass it all around for a clean finish.
Old 12-04-2002, 03:30 AM
b18bEG's Avatar
Default Re: need a redesign (clm_Sol)
this is what i had and i liked it a bunch. except for the no trunk space
those are infinity kappas right? how do yo like them?
[Modified by h22akrd, 8:15 AM 12/4/2002]
Old 12-04-2002, 08:02 AM
RedDawg's Avatar
Default Re: need a redesign (h22akrd)
i love the kappas, nice clean sound, no distortion ever. Excellent sub. I took some new pics tonite and a couple of my new HU, i just installed a Kenwood MP919, awesome HU!!
Old 12-04-2002, 10:57 AM
Desslok's Avatar
Why don't you just make a false floor out of MDF, cut out holes so the Caps can poke through, plexi over the amps, and run 2 fans to cool it. THat way you have trunk space, and you can even throw on a linear actuator if you want to open it.
Old 12-04-2002, 03:56 PM
b18bEG's Avatar
Default Re: need a redesign (sp)
hell yah liner actuators rock!
Old 12-05-2002, 01:17 AM
racerfan's Avatar
u can put plexi glass on top of the amps and then the subs you can put on the side asa long as the capacitators under a plexi so you can put stuf fon top wtihout putting anyhting on top of the amps to heat them up etc
Old 12-05-2002, 11:34 AM
RedDawg's Avatar
what do you mean by a false door?? have any pics of it??
Old 12-05-2002, 12:09 PM
Desslok's Avatar
Can you believe over 5 years of custom installs and I don't have any pics?
Here, this will give you an idea of what I am talking about:
http://jr.stangnet.com/amp.htm
[url=http://www.rtol.net/scornell/2002%20NI%20Trunk.htm]
http://www.rtol.net/scornell/2002%20NI%20Trunk.htm[/url]
http://www.billpalmatary.com/customx/install_feat.htm
[Modified by sp, 9:10 PM 12/5/2002]
[Modified by sp, 9:14 PM 12/5/2002]
Old 12-05-2002, 05:03 PM
hagrid's Avatar
haha
Old 12-07-2002, 03:43 PM
superthug's Avatar
Default Re: need a redesign (5th Gen)
this setup is nice as hell
CooBlueDAB
13
02-09-2005 11:20 AM
bassisliffe
Audio / Security / Video
11-01-2004 02:58 PM
bm3r
06-26-2004 03:55 PM
performula
02-22-2003 06:18 PM
JDubya
22
01-24-2003 06:48 AM
Quick Reply: need a redesign
