NEED hELP w/speaker
Old Oct 17, 2002 | 03:51 PM
jdmfreek671's Avatar
Default NEED hELP w/speaker
y left speaker doesn't work. Its located in the driver side door panel i got a 97 civic ex i checked the fuses and wiring already...do u got any other suggestions on where i can check.The rest of my speakers work except for that only one in my left door panel.WHat can be the problem.... ??????...-thanks...
Old Oct 17, 2002 | 07:22 PM
K.Lund's Avatar
Default Re: NEED hELP w/speaker (jdmfreek671)
Have you pulled the speaker out and tested it? Most of the time if the system is stock, it is a blown speaker.
Old Oct 18, 2002 | 09:22 AM
yea i already tested the speaker...it works fine..and i took another speaker and tested it w/that side and it didnt work..im thinkin it might be the wiring but i checked the wiring already and didnt see nothing odd.any more suggestions?
Old Oct 18, 2002 | 09:24 AM
o_Rage_o's Avatar
take a meter and check for continuity..there might be a break between your door panel wire and the actual deck..
before you do however, check the connections at the back of the deck..wiggle them if you have to, and fix/sauder/reconnect anything that isn't a 100% connection
-Rage
Old Oct 18, 2002 | 11:09 AM
Default Re: NEED hELP w/speaker (o_Rage_o)
Alright imma go ahead and check my player once i get off work.-THANkz
Old Oct 20, 2002 | 08:33 AM
damn i did that already ill prolly bring it to some audio shop but i hope they don't charge a gripp or even trying to jipp me...aiite thanks but if any other suggestions or thoughts..jes dropp it like itz hott.peacccee!
Old Oct 22, 2002 | 03:49 PM
SeaBass's Avatar
From: Clueless like Shaggy n Scooby before commercial, break
well, my bro was complaining that only one speaker was working. We check the connections and everything was tight. Then I checked his Sony deck and found that the settings were set to only play on one side. That's why only 1 speaker was playing!
bigdaddyluck200
Audio / Security / Video
Dec 10, 2013 06:53 AM
FlewByU352
Dec 22, 2010 04:01 PM
gqkris
21
Sep 23, 2009 11:10 AM
n0 iNTegRiTY
Jun 30, 2003 02:59 PM
Overdrive440
Sep 21, 2002 11:46 AM
