need help with system??
Old Jan 24, 2005 | 01:40 PM
Eg6xCiViCxSi's Avatar
Default need help with system??
i have a problem everytime i listen to my system it sounds ok untill i drive and if i hit a bump or sumthin it will make my subs do all sorts of **** and when i sit at the light i can hear my car idle through the subs does any one no wut that problem is? any help would be good and o yeah if i hit my deck on the side it stops the comes bac
Old Jan 24, 2005 | 03:27 PM
93civicEX's Avatar
usually when you hear engine noises through speakers, but not subwoofers, when you have cheap-o rca wires running along side the power wire. How are your wires run?
Old Jan 24, 2005 | 04:01 PM
zumiez007's Avatar
Default Re: (93civicEX)
check your grounds. Make sure they are on bare metal. Use a dremel to sand down the ground points.
Old Jan 24, 2005 | 04:39 PM
the RCA wires are the stinger kind and i dont have them by the power wire i just checked on it to make sure im using a panasonic deck with a RF type r x3 amp and 2 jl audio w3s
MrSnake
Aug 22, 2008 10:11 AM
ChrisTApher05
Audio / Security / Video
24
Feb 29, 2008 01:37 PM
accord64
Oct 1, 2007 06:32 AM
projektvtec
Sep 8, 2005 07:18 AM
GSR-REX
13
Sep 6, 2002 07:27 PM
