subs not working...please help
Old Sep 6, 2005 | 07:32 AM
projektvtec's Avatar
Default subs not working...please help
i was in the car with my friend and all of sudden his subs just stopped working. the fuses are fine. the light on the amp is on so the amp is getting power.so i narrowed ir down to the speaker wires and the subs must be fucked up. all the wires were connected fine and while i was checking the wires and stuff the subs would cut in and out for like 5 seconds. so i dont think that the speakers blew. i was thinking maybe i should replace the speaker wires all together. if so someone let me know. one last thing is that we have an home air conditioning wire hooked up from the deck to the rem spot on the amp. but i dont think that should be a problem because its worked for 2 months with that wire and i dont think the amp would even power up if that wire was shot. someone please help. im goin crazy with this thing.
Old Sep 6, 2005 | 09:23 AM
sleeperteg's Avatar
Default Re: subs not working...please help (projektvtec)
this is gonna sound kinda funny but have you check the wire leads that plug into the sub? i used to work as a car audio salesman and you'd be amazed at how many times i have seen this problem and as soon as we pull the subs out the box for a warrany exchange we see a loose or unplugged wire.
Old Sep 6, 2005 | 09:25 AM
Default Re: subs not working...please help (sleeperteg)
i checked them just by looking through the holes of the bandpass box but i will def re-examine that. thank u for your reply
Old Sep 6, 2005 | 12:08 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projektvtec &raquo;</TD></TR><TR><TD CLASS="quote">i checked them just by looking through the holes of the bandpass box but i will def re-examine that. thank u for your reply</TD></TR></TABLE> One of the problems with a bandpass box is you can't hear when the speaker is distorting, so what ends up happening is you can burn the VC and end up with a dead spot, the way to check for this is to move the cone, forward or backwards a little, with music playing, if it starts to play, and then stops, and plays again if you move the cone a bit, then it has a dead spot, or the other thing that can be wrong if the same thing happens, [moving cone gets it to work] is there can be a problem with the tensil wires, [the wires that run from the term. to the VC, (cone)] there may be a brake in them some place, [normally right where they are soldered to the term. or where they are connected to the VC wires, where they make contact with the cone.
Although there can be other things wrong, like wiring, connections and even wires shorting, or the amps protections circuits kicking in, the ones described above are common with bandpass box's. 94
Old Sep 7, 2005 | 06:44 AM
sleeperteg's Avatar
Default Re: subs not working...please help (fcm)
if the problem is in anyway related to the voice coils... get rid of those subs... see if the place you got them from might still have a warranty or exchange program for them...
Old Sep 7, 2005 | 07:56 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeperteg &raquo;</TD></TR><TR><TD CLASS="quote">if the problem is in anyway related to the voice coils... get rid of those subs... see if the place you got them from might still have a warranty or exchange program for them... </TD></TR></TABLE> Ditto that. 94
Old Sep 8, 2005 | 07:18 AM
thank u for all your helps guys
98civdx
Audio / Security / Video
Jan 3, 2012 09:12 PM
ChrisTApher05
24
Feb 29, 2008 01:37 PM
rockin_remz
May 27, 2006 07:30 PM
TheAutoboxer
Jul 15, 2003 11:10 AM
wessieball
30
Mar 19, 2002 06:10 PM
