need help with subs
Old Aug 23, 2004 | 08:11 PM
cheetah64's Avatar
Default need help with subs
Ok so I just bought two 10" Bazooka subwoofers and I am not exactly sure what to be looking for in an amp. THe subs have an rms of 200 watts and are 4 ohms each. Now should I be looking for a mono sub with 200 watts at 2ohms and connect the two subs in parallel, should I look for a sub with 400 watts at 4 ohms and connect the subs in series, or is there something else that i should be doing? The whole amp thing is really confusing right now and im trying to stay as cheap as i can and still get as much power out of them as i can. thanks for the help
Old Aug 23, 2004 | 08:25 PM
bodiez's Avatar
Hit the floor!
Default Re: need help with subs (cheetah64)
i see no reason to do anything but the mono sub parallel really. DOnt waste money on a series setup
Old Aug 23, 2004 | 08:37 PM
cheetah64's Avatar
Default Re: need help with subs (bodiez)
so if i get an amp that is rated at 150 watts rms at 1 channel on 2 ohms then 150 would be going to each of the subs when in parallel or only 75 watts?
Old Aug 24, 2004 | 05:28 AM
bassisliffe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cheetah64 &raquo;</TD></TR><TR><TD CLASS="quote">Now should I be looking for a mono sub with 200 watts at 2ohms </TD></TR></TABLE>
no, look for a mono amp that does 400 rms at 2ohm
JDMcivicSiEG6
Audio / Security / Video
Mar 12, 2008 09:02 PM
hondaZvic
17
Dec 14, 2004 08:38 PM
NavyHonda95
Oct 22, 2004 04:31 AM
SHystrdyGSRtdy
Sep 8, 2004 12:11 PM
nver2
17
May 4, 2004 02:09 PM
