Compustar 2wfm900-as install into Civic
Old Dec 17, 2005 | 10:24 PM
civic_speed99's Avatar
Default Compustar 2wfm900-as install into Civic
New problem. I have the wired hooked up for my parking lights to flash. They were working and the connection seems good, but they won't flash now. Any imput?
Modified by civic_speed99 at 6:48 PM 1/13/2006
Old Dec 18, 2005 | 08:55 AM
fcm's Avatar
fcm
Old Fart
Default Re: Compustar 2wfm900-as install into Civic (civic_speed99)
1- Yes your 99 Civic, [if that is what it is] will need a second ign. [yellow in car]
2- No your car does not need a second acc.
3- It is the output from the relay and gets connected to your cars 2nd ign. wire, [yellow] the Green/red, [pin 7 CN1] is ign. 1, [connects to cars black/yellow ign. 1 wire]
Yes you car needs that relay for 2nd ign. I hope this helps, feel free to IM me if you need more help. 94
Old Dec 18, 2005 | 01:01 PM
Thanks FCM... I sent you a PM.
Old Dec 19, 2005 | 06:01 PM
Got it installed and it is working. I couldn't find the wire for the trunk trigger though. On my sheet is said it is a blue/black wire in the dirvers kick, but I can't find it. Any help?
Old Dec 19, 2005 | 07:10 PM
fcm's Avatar
fcm
Old Fart
Default Re: (civic_speed99)
It is also on oem alarm connector to the right of the steering column 94
Old Dec 19, 2005 | 08:29 PM
I'll check it out tomorrow.
Old Dec 22, 2005 | 03:49 AM
7808's Avatar
what did you have to use a relay for? was there any problems cause of the factory anti theft?
Old Dec 22, 2005 | 04:52 AM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">what did you have to use a relay for</TD></TR></TABLE>
Needed to create an additional output to power IGN2 circuit.
Old Dec 22, 2005 | 08:10 PM
I had no problems at all. As for the factory anti-theft I don't know. The car already had an alarm on it when I bought it and it didn't have the factory remotes so I guess it was removed.
Old Dec 23, 2005 | 08:24 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_speed99 &raquo;</TD></TR><TR><TD CLASS="quote"> The car already had an alarm on it when I bought it and it didn't have the factory remotes so I guess it was removed.</TD></TR></TABLE> No biggy, on those cars I remove, [unplug] the oem alarm, reroute and use a lot of the wiring on the oem alarm harness for the new alarm, I just do not mount the aftermarket alarm, alarm/starter where the oem alarm brain was, [too easy for crooks to find]. 94
Old Dec 23, 2005 | 08:40 AM
Oh I did a nice job on the hide. The brain I have didn't fit to well there. So I got creative.
Old Dec 23, 2005 | 06:21 PM
suspendedHatch's Avatar
Did you find that trunk trigger wire? What year is the Civic? It will be in the bundle of wire going down the driver's door sill. I've had problems finding that wire too so what I do is go right to the trunk latch and check it there. It often branches off into several wires of the same color. Nothing a little time with the voltmeter can't sort out.
The car I'm speaking of didn't have an oem alarm.
Modified by suspendedHatch at 9:59 AM 12/28/2005
Old Dec 23, 2005 | 10:04 PM
I didn't look yet. It hasn't been up on the priority list. I may look tomorrow if the weather is nice again. It is a 99 Ex.
Old Dec 24, 2005 | 09:11 AM
fcm's Avatar
fcm
Old Fart
Default Re: (suspendedHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch &raquo;</TD></TR><TR><TD CLASS="quote">Did you find that trunk trigger wire? What year is the Civic? It will be in the bundle of wire going down the driver's door sill. I've had problems finding that wire too so what I do is go right to the trunk latch and check it there. It often branches off into several wires of the same color. Nothing a little time with the voltmeter can't sort out.</TD></TR></TABLE> Trunk/hatch trigger is in the oem alarm harness. 94
Old Dec 24, 2005 | 11:41 AM
Found it... Thanks
Old Dec 24, 2005 | 12:14 PM
Ok when I attach the negative trunk trigger to the blue black wire on the column, I can't arm the car or lock the doors. I am getting 3 flashes of the parking lights, but when I cut the wire it works fine.
Old Dec 24, 2005 | 03:18 PM
7808's Avatar
is the4 relay you guys talkin about buil in the alarm or pre wired?
Old Dec 24, 2005 | 06:34 PM
Relay for what?
Old Dec 25, 2005 | 09:00 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_speed99 &raquo;</TD></TR><TR><TD CLASS="quote">Ok when I attach the negative trunk trigger to the blue black wire on the column, I can't arm the car or lock the doors. I am getting 3 flashes of the parking lights, but when I cut the wire it works fine.</TD></TR></TABLE> Not a blue/black "on" the steering column, blue/black in oem alarm plug to the "right" of steering column
Did you test the wire, if the trunk/hatch light is on and you close the lid the proper trunk/hatch trigger wire will read 12V+, when you open the trunk/hatch it will read ground.
And, [violet/black] of the Compustar. 94
Old Dec 25, 2005 | 12:00 PM
Yeah it was on the alarm plug. Well pretty sure. I'll check again later.
Old Dec 27, 2005 | 10:51 AM
Yeah I did find the wrong one. Stupid mistake by me cuz I didn't check it since it was cold. The oem alarm one is the big green one below the dash correct?
Old Dec 27, 2005 | 06:51 PM
fcm's Avatar
fcm
Old Fart
Yes it is normally a green plug with around 12 wires, do not test these wires with a test light, use only a DVM, one of the wires may be a key sense and you can damage the ICU, [no key in ign. chime] 94
Old Dec 27, 2005 | 08:16 PM
I found it. Thanks for the info.
Old Jan 1, 2006 | 08:34 AM
user 72830283's Avatar
is there a better installation manual somewhere for this thing? cuz what comes in the box isnt helping me a lot, i was just curious if someone had pulled a DIY on this earlier..?
Old Jan 1, 2006 | 10:12 AM
fcm's Avatar
fcm
Old Fart
Default Re: (pr3d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pr3d &raquo;</TD></TR><TR><TD CLASS="quote">is there a better installation manual somewhere for this thing? cuz what comes in the box isnt helping me a lot, i was just curious if someone had pulled a DIY on this earlier..?</TD></TR></TABLE> IM sent. 94
