kicker components in a Sol
Old Jun 4, 2005 | 06:48 AM
CaptivaBlue's Avatar
Default kicker components in a Sol
Hey all, I have a 94 Sol that I want to put some kicker components up front and kicker midbass in back. The speakers are much deeper than stock. Can I just cut the speaker basket to fit? Will the window be in the way when rolled down? Would I have to make plates to bring the speaker out further into the cabin?
Old Jun 4, 2005 | 05:51 PM
fcm's Avatar
fcm
Old Fart
Default Re: kicker components in a Sol (CaptivaBlue)
You will at least have to cut a hole in the back of the stock plastic speaker mounts to allow for the bigger and deeper magnets, you may even have to make a "spacer ring" to reduce the depth of the Kicker speaker, but what you should do is make new custom MDF speaker mounts to replace the stock plastic ones, [a speaker mounted to wood will sound better then the same speaker mounted to plastic.
There are more then a few posts, with links, about mounting speakers in Honda/Acura doors, all you have to do is search. 94
The94delslow
25
Mar 3, 2019 12:29 PM
Phil_McKrevice
Dec 1, 2015 08:55 PM
MOTOCOMPO
Audio / Security / Video
Nov 23, 2005 11:59 PM
samdawgsol
Feb 13, 2003 10:33 AM
