installing my stereo...
Old Mar 12, 2007 | 05:08 PM
Fo-Do Fanatic's Avatar
Default installing my stereo...
I've been trying to instal my stereo for about 3 hours now, and i can get the son of a bitch to turn on. i have all the correct wire diagrams and everything. i have the right power and ground wire hooked up, but it still wont turn on. the fuses are ALL good to.
any help?
Old Mar 12, 2007 | 05:13 PM
B18C_EJ8's Avatar
Make & model of car would help...
Have you verified with a meter that you're getting good constant power & switched power?
Old Mar 12, 2007 | 05:17 PM
Default Re: (B18C_EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">Make & model of car would help...
Have you verified with a meter that you're getting good constant power & switched power?</TD></TR></TABLE>
dont laugh, its just the daily. 1992 Geo Prizm.
i haven't done that yet.. i dont have one. is there a way that i can just test it?
Old Mar 12, 2007 | 05:35 PM
B18C_EJ8's Avatar
You could also use a test light.
And how did you verify fuses were actually good without a meter or test light? Did they just "look" good?
Old Mar 12, 2007 | 06:08 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">You could also use a test light.
And how did you verify fuses were actually good without a meter or test light? Did they just "look" good? </TD></TR></TABLE>
well i didn't replace the 2 7.5amp ones. i didnt wanna pay 5 bux for 3 off them. and i pulled them all out and the did 'look' good.
Old Mar 12, 2007 | 06:15 PM
02 accord's Avatar
Default Re: (b00sted-Hatch)
Connect the yellow and red wires to the pos battery terminal, and connect the black to neg terminal. Headunit should turn on. If it does, then you have a power/wiring problem.
Old Mar 12, 2007 | 06:20 PM
Default Re: (02 accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 02 accord &raquo;</TD></TR><TR><TD CLASS="quote">Connect the yellow and red wires to the pos battery terminal, and connect the black to neg terminal. Headunit should turn on. If it doesn't, then you have a power/wiring problem.</TD></TR></TABLE>
if it does turn on when i do that,should i just hard wire it to the neg/pos?
Old Mar 12, 2007 | 06:54 PM
02 accord's Avatar
When it does turn on, it tells you that your headunit works. Then you need to start looking at your wiring/fuses to make sure you're getting power at the radio harness.
Old Mar 12, 2007 | 06:58 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 02 accord &raquo;</TD></TR><TR><TD CLASS="quote">When it does turn on, it tells you that your headunit works. Then you need to start looking at your wiring/fuses to make sure you're getting power at the radio harness.</TD></TR></TABLE>
that would take SOO much time. but like i asked before. could i just hardwire it to the battery itself? or would it still be draining powre from the batter if i turned the stereo off.
Old Mar 13, 2007 | 04:09 AM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">that would take SOO much time.</TD></TR></TABLE>
Then if it's such a bother for you, go away and stop wasting our time if you're going to balk at our advice.
However, if you've verified that the constant wire is the problem, then yes, you can run a wire from the battery.
Modified by B18C_EJ8 at 6:00 AM 3/13/2007
Old Mar 13, 2007 | 05:50 AM
im not saying that i wouldn't do it just saying it would take a while, but id do it lol.
so if i ran the yellow and red wire to the positive terminal id just fine? and just make a ground somewhere? that wouldn't cause my battery to die right?
Old Mar 13, 2007 | 06:08 AM
B18C_EJ8's Avatar
If you run the yellow and red wire to the battery, then the radio will remain on all the time and you will have to remember to turn it off when you shut the car off.
That's why we're trying to tell you to diagnose the problem properly so it will work as intended.
Old Mar 13, 2007 | 06:09 AM
B18C_EJ8's Avatar
However, you still have not answered the basic question of whether or not you've tested the constant & switched power leads going to the radio with a meter or test light...
Rickdogg
Sep 6, 2011 08:44 PM
1qukcb7
May 24, 2010 09:18 AM
deerman2701
Audio / Security / Video
11
Dec 10, 2008 02:12 PM
jdmjaser
Apr 16, 2006 07:41 PM
Muckman
21
Jul 9, 2004 08:51 AM
