12v Switched Power Source
Old May 3, 2004 | 10:57 AM
Muckman's Avatar
Moderator in Chief
Default 12v Switched Power Source
Wheres a good spot to get a 12v switched (accessory) power source from? I know theres one switched 12v power source plug on the fuse box. But I need a few sources for various things (gauges, sensors etc).
Old May 3, 2004 | 11:40 AM
TurboBumblBee's Avatar
Default Re: 12v Switched Power Source (Muckman)
get it at the actually ignition harness
Old May 3, 2004 | 12:01 PM
Muckman's Avatar
Moderator in Chief
Default Re: 12v Switched Power Source (Boostfedb18c1)
Would I have to T off a wire there? I need a super clean power source for a wideband controller that is hypersensative to power and ground.
Old May 3, 2004 | 12:44 PM
ShaunRR's Avatar
HT White Ops
Community Builder
If you are talking about T taps, then no. Don't ever use those for anything, they cut almost completely through the wire. Always solder your connections, this is what the MECP recomends.
Old May 3, 2004 | 01:10 PM
Default Re: 12v Switched Power Source (rochesterricer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rochesterricer &raquo;</TD></TR><TR><TD CLASS="quote">If you are talking about T taps, then no. Don't ever use those for anything, they cut almost completely through the wire. Always solder your connections, this is what the MECP recomends.</TD></TR></TABLE>
T taps suck ***
Old May 4, 2004 | 10:19 AM
bruthaboost's Avatar
You can set up your own switched relay. I was in the exact situation (I needed power for 8+ accessories. I just went to an electronics shop and picked up a couple of multi-output relays and used the accessory voltage for the switch. Came out very clean. Let me know if you need pics.
Old May 4, 2004 | 10:25 AM
rjr162's Avatar
Hate to tell you but all that power comes off the same source anyhow. Not to mention your ignition line in the steering column is going to be one of the bigger ignition lines you'll find in your car and be able to handle the load better
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">Would I have to T off a wire there? I need a super clean power source for a wideband controller that is hypersensative to power and ground.</TD></TR></TABLE>
Old May 4, 2004 | 10:58 AM
nOOber's Avatar
Default Re: 12v Switched Power Source (rjr162)
if 'clean power' is the issue here, going to the IGN harn should be fine. He can use ACC and IGN from there as triggers for the relays that send the 'clean power'.
and as above: t taps suck ***.
Old May 5, 2004 | 01:30 PM
From: eating the shit out of pizza in raleigh, NC, USA
the 12v accessory wire for a 2000 gsr is the yellow wire in your ignition harness. this is the best place to get your power from. dont use and kind of crimp connectors. be sure to splice, solder, and tape it! ground the **** to the chassis.
Old Jul 1, 2004 | 03:16 PM
EVIL_AWD's Avatar
Default Re: 12v Switched Power Source (2ndchancehonda)
OK so say I have 2 gauges and an aftermarket ignition, can I tap all 3 accessories into the same yellow 12v accessory wire on the ignition harness without having to worry about starting my car on fire because of a wire getting too hot? Anybody with experience installing numerous accessories please let me know the best way to get a switched 12v source for say 3-5 accessories. Thanks in advance.
Old Jul 1, 2004 | 09:01 PM
fcm's Avatar
fcm
Old Fart
Default Re: 12v Switched Power Source (ITR420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR420 &raquo;</TD></TR><TR><TD CLASS="quote">OK so say I have 2 gauges and an aftermarket ignition, can I tap all 3 accessories into the same yellow 12v accessory wire on the ignition harness without having to worry about starting my car on fire because of a wire getting too hot? Anybody with experience installing numerous accessories please let me know the best way to get a switched 12v source for say 3-5 accessories. Thanks in advance.</TD></TR></TABLE>
The absolute best way is to run a 12ga or 10ga ,[depending on load] right from batt. [with fuse at batt] to a 25/30 amp SPST relay and use acc. or ign2 to trigger relay, then you can safely draw up to 25 amps off relay.
If all you need is less then, say 8 amps you can get that at ign. harness, just unplug ,pop out acc.,ign.,or ign.2 metal pin ,open one of the insulation grips,strip and pre tin wire, clamp down to metal pin with grip, solder wire to pin,and reinstall pin into plastic plug. "clean" and no cutting or stripping oem wireing and no Ttaps
hope this helps. 94
Old Jul 1, 2004 | 09:12 PM
toyzbus's Avatar
Default Re: 12v Switched Power Source (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">
hope this helps. 94</TD></TR></TABLE>
Just use the accessory feed from your radio to switch your relay on and off.
Old Jul 1, 2004 | 09:25 PM
fcm's Avatar
fcm
Old Fart
Default Re: 12v Switched Power Source (toyzbus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyzbus &raquo;</TD></TR><TR><TD CLASS="quote">
Just use the accessory feed from your radio to switch your relay on and off.</TD></TR></TABLE>
There is acc. and ign.2 on fuse box, no need to go to radio. 94
Old Jul 1, 2004 | 10:16 PM
bassisliffe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">Wheres a good spot to get a 12v switched (accessory) power source from? I know theres one switched 12v power source plug on the fuse box. But I need a few sources for various things (gauges, sensors etc).
the battery
Old Jul 2, 2004 | 02:25 AM
EVIL_AWD's Avatar
Thanks, but I have one more question for you then. Do I need to get a seperate relay for each accessory or can I run all of my accessories off the same relay as long as they don't draw more than 25 amps? I'm not real familiar with relays so if someone could maybe draw me up some sort of diagram it would be greatly appreciated. Thanks again.
Old Jul 2, 2004 | 06:19 AM
fcm's Avatar
fcm
Old Fart
Just the one relay, just like the acc. or ign. outputs from ign. switch supply more then one thing.
hope this helps. 94
Old Jul 2, 2004 | 07:06 AM
EBP_SI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2ndchancehonda &raquo;</TD></TR><TR><TD CLASS="quote">be sure to splice, solder, and tape it! ground the **** to the chassis.</TD></TR></TABLE>
never use tape to cover a connection, thats just ghetto. use heat shrink tubing.
Old Jul 2, 2004 | 08:14 AM
toyzbus's Avatar
Default Re: 12v Switched Power Source (EBP_SI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EBP_SI &raquo;</TD></TR><TR><TD CLASS="quote">
never use tape to cover a connection, thats just ghetto. use heat shrink tubing.</TD></TR></TABLE>
If you are splicing in to a source and not cutting things, you can't use heat shrink. Just make sure to use a quality tape (Scotch Super 33 and 88 are the only ones I trust) I know 3M did also come out with a super nice method of insulating connections, but I have only seen it from a rep and don't know the name of it.
Old Jul 2, 2004 | 08:35 AM
ShaunRR's Avatar
HT White Ops
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyzbus &raquo;</TD></TR><TR><TD CLASS="quote">If you are splicing in to a source and not cutting things, you can't use heat shrink. Just make sure to use a quality tape (Scotch Super 33 and 88 are the only ones I trust) I know 3M did also come out with a super nice method of insulating connections, but I have only seen it from a rep and don't know the name of it.</TD></TR></TABLE>
You can still use heat shrink. Just splice the wire so you can run it parallel to the source wire.
Personally, I like to put tape over the heat shrink, but that is probably overkill.
Old Jul 2, 2004 | 11:50 AM
hybridzOr's Avatar
what about those one tape in a can thing? the liquid tape......
Old Jul 2, 2004 | 04:27 PM
Default Re: 12v Switched Power Source (Hybrid Racer.)
what about silicone
Old Jul 9, 2004 | 08:51 AM
ef-sihatch's Avatar
Default Re: 12v Switched Power Source (bassisliffe)
I am a MECP certified tech...just get it from the ignition harness. Please do not use a t-tap.
caliskier
Feb 2, 2008 10:44 AM
civc_tt
Aug 13, 2006 07:33 PM
doggworld1233
Audio / Security / Video
May 31, 2006 09:11 PM
jadugartir
May 22, 2005 01:26 PM
motion
May 2, 2005 02:13 PM
