Ignition kill switch
Old May 10, 2008 | 08:43 PM
99vSmEj8's Avatar
Default Ignition kill switch...please
sorry guys.....I didnt search, i cant right now, so please please please can some one please answer my question,......
- is it safe to use a 25 amp 12v toggle with 14 guage wire to make a kill switch using the main engine harness.
-hack the red ignition wire and run in into the car?
not for my car, friend almost fell victim to the shmuck of the world...
thanx lots
Modified by 99vSmEj8 at 9:52 PM 5/10/2008
Old May 11, 2008 | 12:49 PM
fcm's Avatar
fcm
Old Fart
Default Re: Ignition kill switch...please (99vSmEj8)
Yes you could, but why?
It would be more effective to install a switch on the ground to the PGM-FI Main Relay, it is a low current ground, [a 1A switch is more then big enough and a lot easier to hide] and it will shut down the fuel pump, the injectors, one of the powers to the ECU/ECM and a few engine sensors. ; 94
Old May 11, 2008 | 02:48 PM
99vSmEj8's Avatar
Default Re: Ignition kill switch...please (fcm)
thanx man, im gonna look into your idea... thanx again
Old May 11, 2008 | 03:46 PM
Unbreakable6161's Avatar
and don't just kill the main relay, relocate it.
Old May 13, 2008 | 06:02 PM
beastman@'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">Yes you could, but why?
It would be more effective to install a switch on the ground to the PGM-FI Main Relay, it is a low current ground, [a 1A switch is more then big enough and a lot easier to hide] and it will shut down the fuel pump, the injectors, one of the powers to the ECU/ECM and a few engine sensors. ; 94</TD></TR></TABLE>
Do you know of a DIY with pictures for doing this? I know there are some flagged DIYs but I want to do something in addition to fuel pump kill switch, or is this the same thing? All this security gets me confused. I have a headache.
Old May 14, 2008 | 11:56 AM
fcm's Avatar
fcm
Old Fart
Default Re: Ignition kill switch...please (beastman@)
Installing a switch on the ground to the PGM-FI Main Relay, [ground to fuel injector relays coil] will cut power to the fuel injectors, the fuel pump, one of the powers to the ECU/ECM and a few engine sensors, [the ground is a black lead, it is low current, less then 250mA].
Old May 20, 2008 | 08:07 PM
beastman@'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">Installing a switch on the ground to the PGM-FI Main Relay, [ground to fuel injector relays coil] will cut power to the fuel injectors, the fuel pump, one of the powers to the ECU/ECM and a few engine sensors, [the ground is a black lead, it is low current, less then 250mA]. </TD></TR></TABLE>
Where is the ground wire? Is this as simple as doing a fuel pump kill switch?
Old May 20, 2008 | 08:36 PM
What car do you have? On many older hondas its located right above the hood release, its a big relay, nothing like the small ones used for the k-series. If I remember right there's only one ground wire, its a great kill, have done it to nearly all the older hondas I've worked on.
Old May 21, 2008 | 09:45 AM
baller status's Avatar
Default Re: Ignition kill switch...please (Unbreakable6161)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Unbreakable6161 &raquo;</TD></TR><TR><TD CLASS="quote">I don't think you want your kill switch under the car exposed to the elements and flying debris. You don't want to run over a raccoon and have its bloody carcass switch off your fuel pump. You'll be in trouble when his raccoon family catches up to you and avenges his death.</TD></TR></TABLE>
That's some sick and twisted **** to say. I laughed, then I immediately felt guilty. Karma's a bitch.
Old May 21, 2008 | 02:54 PM
Default Re: Ignition kill switch...please (baller status)
lmao thats what suspended hatch said once, for some reason it gave me a good laugh.
Old May 21, 2008 | 04:26 PM
fcm's Avatar
fcm
Old Fart
94<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beastman@ &raquo;</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE> Even simpler, as it is a low current ground, [less then 250mA] instead of a "high current" 12V+, [10A] so all that is needed is a small, [easy to hide] 1A SPST, [on/off] switch, this may help... http://www.tegger.com/hondafaq/mainrelay.html
Old May 24, 2008 | 05:20 PM
beastman@'s Avatar
So you just put an extension on the ground from the relay and a spst wherever you want? (within reason)
Old May 25, 2008 | 08:13 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beastman@ &raquo;</TD></TR><TR><TD CLASS="quote">So you just put an extension on the ground from the relay and a spst wherever you want? (within reason)</TD></TR></TABLE> Yes. 94
Old May 30, 2008 | 03:55 PM
beastman@'s Avatar
What gauge is the ground wire? And it's black?
Old May 30, 2008 | 09:07 PM
hatchinprogress's Avatar
wow thats a good idea (much better then the same old fuel kill switch), 1 more layer of security to add
Old May 31, 2008 | 06:29 AM
fcm's Avatar
fcm
Old Fart
Yes it is black and it will be 18/16 gauge. 94
WetCoastRacing
May 20, 2017 02:28 AM
jjos
Audio / Security / Video
Apr 26, 2016 02:09 PM
jakfrost84
Mar 22, 2011 08:41 AM
Feli
Feb 28, 2010 09:40 AM
Christine
Oct 1, 2001 08:38 AM
