Fuel Pump Kill
Old May 31, 2008 | 08:04 AM
beastman@'s Avatar
Default Fuel Pump Kill
Is it ok to put your kill switch anywhere along the fuel pump wire? In the Cause for alarm fuel kill the pictures show the kill installed down by the drivers running board. Could you extend the wire that is right under the seat (right where it comes up from the fuel pump) and go to the passenger side?
Old May 31, 2008 | 08:55 AM
B18C_EJ8's Avatar
No. Too much added resistance between the extra wire & switch.
If you're going to do this, you can mount the switch where you originally planned, but it will need to drive a relay instead of directly controlling the pump.
Old May 31, 2008 | 10:27 AM
beastman@'s Avatar
Default Re: (B18C_EJ8)
Are you saying there will be too much resistance because it will have to travel further?
The way I'm planning is only about 1.5 feet away, so 3ft total of extension wire.
Old May 31, 2008 | 05:34 PM
bigsyke's Avatar
Default Re: (beastman@)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beastman@ &raquo;</TD></TR><TR><TD CLASS="quote">Are you saying there will be too much resistance because it will have to travel further?
The way I'm planning is only about 1.5 feet away, so 3ft total of extension wire.</TD></TR></TABLE>
thats a what, 18ga wire? you know fuel pumps cut the GPH quite a bit when the voltage drops. A relay is your BEST and almost only option here.
98y8
May 5, 2010 12:06 PM
Civic Si Kid
Audio / Security / Video
May 17, 2009 12:26 PM
CivicPride97
May 20, 2008 05:21 PM
efking1985
22
Feb 13, 2007 06:58 PM
EJ8 GSR-T
Dec 25, 2006 06:46 PM
