How to wire everything up?
Old Jan 24, 2004 | 01:24 AM
Geone's Avatar
Default How to wire everything up?
Here is my setup:
Blaupunkt gta 5000 4ch+1sub amp
2x Velocity 6x9
2x Blaupunkt GT mid bass for front doors
2x blaupunkt tweeters
Blaupunkt woodstock dab52 head unit
What is the best way of wiring averything up?
What kind of subwoofer do i need 10'' or 8''.
Thanks for any help
Old Jan 24, 2004 | 09:37 PM
roydogg's Avatar
Default Re: How to wire everything up? (Geone)
If you don't have a idea on how to hook a system up I would suggest that you take it to a shop and have them install it or you can do it with a friend who knows how.
1) buy a 4 or 2 gauge wiring kit for like 50 bucks
2) Install the kit
3) Turn ignition and hope you don't smell smoke
btw instruction diagram should be in the wire kit and then you should get an idea on what goes where . And buy 1 12" sub that requires a small box.
Good luck and keep me posted, if you have any questions I'll try my best to answer them but it's actually self explanatory when you sort the wires.
Roy
Old Jan 25, 2004 | 01:29 AM
Geone's Avatar
System is up and ready. Each of the four speakers uses its own exit from the amp, except the tweeters that use the front speakers exit throught a crossover. Is there a way that i can get more power from the system (bridged mode?). What if the power line going to amp is thinner than required is there a problem? Thanx for your answer.
Old Jan 25, 2004 | 09:06 AM
roydogg's Avatar
What does the amp require 4 gauge or 8 guage power wire? As far as bridge mode you can do that but you'll won't have L&R unless you just run the 2 fronts bridged and run the rear off the radio. Why don't you sell the amp and get a 5 channel amp that pushes more power. If not then 1 4channel amp and a mono amp.
05CivicSE
Audio / Security / Video
Mar 13, 2006 10:32 AM
redGSRguy
Mar 16, 2004 04:45 PM
ITACivic
Jul 30, 2002 02:08 PM
HaleLude
Jul 10, 2002 09:29 PM
IdotheSHOCKER
Jun 26, 2002 02:49 PM
